Local Time 18:27 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : VS1053 support
tenij000
Posted: 02:09pm 14 Aug 2025
VS1053 support
do need to share the  CLKpin, MOSIpin, MISOpin from display
Posted: 03:03pm 14 Aug 2025
Personally I wouldn't share it with a display, although a SD card might be ok. I haven't tried sharing it with a display because that channel is pretty busy.
Posted: 03:20pm 14 Aug 2025
You can't share them. It must have a dedicated SPI channel
tenij000
Posted: 03:53pm 14 Aug 2025
PicoMite MMBasic RP2350A Edition V6.00.02RC26
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION DEFAULT COLOURS WHITE,
OPTION KEYBOARD US
OPTION CPUSPEED (KHz) 150000
OPTION LCDPANEL CONSOLE ,,, FFA500, 50,NOSCROLL
OPTION DISPLAY 20, 40
OPTION LCDPANEL ILI9341, LANDSCAPE,GP15,GP14,GP13,GP20
OPTION GUI CONTROLS 78
OPTION TOUCH GP5,GP7
GUI CALIBRATE 0, 3897, 3858, -899, -668
OPTION SDCARD GP12
OPTION AUDIO GP0,GP1', ON PWM CHANNEL 0
OPTION F8 hello
how gone choose those second spi then if already made 1
tenij000
Posted: 04:27pm 14 Aug 2025
VS1053      →   PicoMite (GPIO)
GND         →   GND
VCC         →   3V3
RST         →   GP10
MISO        →   GP16  (SPI0 MISO)
MOSI        →   GP19  (SPI0 MOSI)
SCK         →   GP18  (SPI0 SCK)
XCS         →   GP13
XDCS        →   GP14
DREQ        →   GP15
Posted: 05:36pm 14 Aug 2025
You can't use the same SPI channel for the display and the VS1053 and the display has to use SYSTEM spi as you can't specify the SPI pins for that option.
I've rearranged the pins a bit to make it fit.
e.g.
'use SPI1 as the SYSTEM SPI. This can be shared with the SD card.
OPTION SYSTEM SPI GP18, GP19, GP16
OPTION LCDPANEL ILI9341, LANDSCAPE, GP14, GP15, GP13, GP20
OPTION TOUCH GP5, GP7
OPTION SDCARD GP4
'SPI1 has been used, now we have to use SPI2
OPTION AUDIO VS1053 GP10, GP11, GP12, GP0, GP1, GP2, GP3
