Local Time 14:30 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Touch Screen - ST7789_300 on a breakout board - PIN HELP
Askjerry
Posted: 04:31pm 21 Sep 2025
I purchased a really nice breakout board on Amazon,
https://www.amazon.com/dp/B0C98G37PW
The board has a 420x320 color TFT... and I have most of the options figured out now.
WebMite MMBasic RP2350A Edition V6.00.03
OPTION SYSTEM SPI GP2,GP3,GP4
OPTION SYSTEM I2C GP8,GP9
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION CPUSPEED (KHz) 150000
OPTION LCDPANEL ST7796S, LANDSCAPE,GP6,GP7,GP5
Written on the board are the pin assignments...
SCLK = GP2   CS = GP5
MOSI = GP3   DC = GP6
MISO = GP4   RST = GP7
IC2 =GP8, GP9
All the above I figured out... just two remaining... and I think they are for the touch screen...
TPRST = 10   TPLNT = 11
I just want to know the correct pins to type in OPTION TOUCH
I tried OPTION TOUCH GP10, GP11 then tried the GUI CALIBRATE, but not seeing any change when I put my finger on the target.
I tried OPTION TOUCH GP11, GP10 and again, no reaction to touching the target.
Of course after each failure... I have to clear the flash, then renter all the options again. (Not horrible, I copy from NOTEPAD++, click on TeraTerm, and Right-click to copy.) But... it's not working... any ideas???
(First post here... let's make it a head scratcher!)
THANKS in advance!!!
Jerry
Posted: 04:57pm 21 Sep 2025
It uses a GT911 i2c capacititive touch controller. This is not supported by MMBasic - sorry.
Askjerry
Posted: 08:46pm 21 Sep 2025
Well Phooey
I guess I won't be able to use the interactive GUI components.
The breakout board has a JOYSTICK... if I can figure that out, it could be used to navigate a menu, and there are 2 buttons... I'll have to think about that.
Thanks for the quick reply,
Jerry
Posted: 09:28pm 21 Sep 2025
  Quote  Of course after each failure... I have to clear the flash, then renter all the options again.
Most Options can be individually removed with :-
OPTION xxx DISABLE
Leaving the rest intact.
Askjerry
Posted: 02:10am 22 Sep 2025
Ok, nice and good to know... that way I don't have to keep restoring each one.
If anyone gets the same breakout board as me... this is what I have currently set...
OPTION CONTINUATION LINES ON
OPTION LCDPANEL ST7796S, LANDSCAPE,GP6,GP7,GP5,,INVERT
It all seems to be working well.
This is the BREAKOUT BOARD that I got.
