Local Time 13:32 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Heartbeat on the 2350B
OA47
Posted: 06:54am 28 Sep 2025
I am a little confused here (AGAIN!!) Here is one of the notes from the Version 6 info.
  Quote  Changes from 6.00.01
Bugs fixed
Various fixes to OPTION LIST
Fixes bug in forward references in PIO assembler when the starting line number is > 1
Fixes bug in PRINT @(x,y) when outputting to a computer console
By default disables HEARTBEAT and enables access to all pins on RP2350B
I have initially used OPTION HEARTBEAT ON to verify that the MMBASIC 6.00.03 was working then OPTION HEARTBEAT OFF and when I tried to use Pin35 (GP25) I get:
  Quote  Error : Pin 35/VREF is invalid
I even tried OPTION HEARTBEAT DISABLE but I still get the same error.
Any suggestions?
OA47
Posted: 07:32am 28 Sep 2025
You might need SETPIN GP25 DOUT now.
(Please avoid using the Pin35 reference if you can - GP25 can be on different pin numbers on different modules!)
Edited 2025-09-28 17:33 by Mixtel90
OA47
Posted: 07:37am 28 Sep 2025
Mick, I have tried SetPin 35, DOUT but made no difference. I want to overcome this saga as I have just received a shipment of PCB's using that pin as an INPUT as I thought from the notes above all was good with this pin.
OA47
Posted: 07:45am 28 Sep 2025
Use the gpn variant. Pin numbers refer to the Pico. The rp2350 uses the same gpno/pin number mapping and pin 35 is vref. See the manual for the pseudo pin number for gp25
OA47
Posted: 07:48am 28 Sep 2025
Thanks Peter, the reason I used the pin numbers is because I had them in an array and loaded them in a for next loop. I will recode and try the GPXX and see how it goes.
OA47
Posted: 07:53am 28 Sep 2025
Peter beat me to it. :)
Edited 2025-09-28 17:55 by Mixtel90
OA47
Posted: 09:05pm 28 Sep 2025
Using SetPin GP25 instead of SetPin 35 has worked ok.
Thankyou
  OA47
OA47
Posted: 10:31pm 29 Sep 2025
I am still not out of the woods, is there a way to use the PIN(GPnn) function where nn is a variable? My previous code just used the pin numbers which were read from an array.
OA47
Posted: 11:02pm 29 Sep 2025
Haven't got a 2350B but this works for the rest.
Array(xx) = MM.INFO(PINNO GPnn)
  Quote  MM.INFO(PINNO GPnn)
Returns the physical pin number for a given GP number. GPnn can be an unquoted string (GP01), a string literal(“GP01”) or a string variable. Ie, A$=”GP01”: MM.INFO(PINNO A$)
Edited 2025-09-30 09:04 by phil99
