Local Time 13:32 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Current reference design for HDMI Pico 2 board
karlelch
Posted: 07:23am 03 Oct 2025
I am looking for the most current reference design for the HDMI version of the Pico 2 board - is it the one that was advertised in the SC article this Spring (Pico 2 Computer) and is linked on their website? If not, could someone please point me to the thread here?
Another question: I uploaded the files from SC to JLCPCB and one part is not available, the 4.7 mH inductor. They have an inductor with similar specs except that it is 45 Ohm instead of 32 Ohm - would that be acceptable?
Many thanks and best
Thomas
Posted: 07:43am 03 Oct 2025
Is this the version that uses a Pico2? The latest version uses an on board RP2350 and has I2S audio so doesn't use those inductors
karlelch
Posted: 07:56am 03 Oct 2025
Its in the .zip ("Pico 2 Computer PCB.zip") on this page:
https://www.siliconchip.com.au/Shop/10/1841
Posted: 08:02am 03 Oct 2025
As it has a 220Ω resistor in series I doubt it will make much difference.
Volhout will let you know if this is wrong.
The SC article is in April 2025, Pico 2 Computer, but so far can't find the TBS thread.
karlelch
Posted: 08:10am 03 Oct 2025
  matherp said  Is this the version that uses a Pico2? The latest version uses an on board RP2350 and has I2S audio so doesn't use those inductors
Can you please point me at the thread with the latest version? Thanks!
Posted: 08:19am 03 Oct 2025
https://www.thebackshed.com/forum/ViewTopic.php?TID=17301&P=11
karlelch
Posted: 08:36am 03 Oct 2025
  matherp said  https://www.thebackshed.com/forum/ViewTopic.php?TID=17301&P=11
Thanks Peter!
