Local Time 11:43 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : TeraTerm in Linux
grroel.tech
Posted: 06:27pm 21 Oct 2025
Hello,
I have installed TeraTerm (under Wine) on Zorin Linux v.18. In this version, installation is very easy; you simply open the .exe file on Wine. The problem is that in TeraTerm I cannot find the serial port to which I have connected the Pico.
I have created the symbolic link to COM:
ln -s /dev/ttyUSB0 ~/.wine/dosdevices/com1
and I have given permissions for dialout:
sudo usermod -a -G dialout $USER
But the COM1 port does not appear when making a new connection in TeraTerm.
I have also tried with the /dev/ttyACM0 port.
Any clues?
Posted: 06:56pm 21 Oct 2025
Did you log out & back in so that the usermod takes effect?
Andy-g0poy
Posted: 07:02pm 21 Oct 2025
Have you found this post?
https://superuser.com/questions/619528/how-to-convert-the-dev-ttyusbn-to-a-com-port-to-use-it-with-wine-in-linux
It looks like some systems need a tweak in the wine registry.
I assume you have logged out and back in again?
that's caught me out a few times :-)
Andy
