Local Time 11:41 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : does Basic run subscript expressions ?
zeitfest
Posted: 11:39am 02 Nov 2025
Just wondering, does Basic accept subscript expressions ?
Eg  where gunge is an array
   foo = gunge(6*j+2)
To me they seemed to be best avoided but they were in use
to some extent.
I am wondering whether to add the capability to my interpreter
(mainly as a result of a boredom tsunami    )
then again it should also handle COMMON named blocks,
adding them would probably be pointless but hey..
toml_12953
Posted: 12:16pm 02 Nov 2025
  zeitfest said  Just wondering, does Basic accept subscript expressions ?
   foo = gunge(6*j+2)
to some extent.
Yes, you can certainly use expressions rather than a numeric constant as an index.
It's a major benefit of arrays.
Posted: 12:31pm 02 Nov 2025
Just be aware of the execution sequence. Sometimes you need brackets to force an expression to work in the way that you want. :)
Posted: 12:35pm 02 Nov 2025
> dim foo, gunge(11), j
> for n=0 to 11 :gunge(n)=n :next
> j=0 : foo = gunge(6*j+2) :? foo
2
> j=1 : foo = gunge(6*j+2) :? foo
8
dddns
Posted: 01:25pm 02 Nov 2025
  Mixtel90 said  Just be aware of the execution sequence. Sometimes you need brackets to force an expression to work in the way that you want. :)
You need inner brackets depending on math or logic to get the correct result.
zeitfest
Posted: 05:22pm 02 Nov 2025
