Local Time 09:41 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBASIC SERVO Command issues.
Askjerry
Posted: 11:56am 23 Nov 2025
I am reading the manual... but obviously missing something
SERVO 1.bas
' Program to run a servo on a PICO 2040
' Servo Signal = GP8
' From the manual page 154...
' As with the PWM command the pins must be set up with SETPIN n,PWM
SetPin GP8, PWM
' From the manual: SERVO channel [positionA][,positionB]
' Looking at the RP2350 chart (There is none for the 2040) it seems
' that GP8 is Channel 4A. I have a continuous turn servo connected to
' GP8. If the range is -120 to +120, then 0 should be center or STOP
' for a continuous turn.
Print "Start"
Servo 4, 0
Pause 2000
PWM 4, OFF
Print "STOP"
END
I would expect the continuous rotation servo to be at or near center... but it takes off spinning hard.
If I change the line to
SERVO 4,-100
To get a different motion, it fails...
[17] Servo 4, -100
Error : Syntax
If I attempt to use a variable...
SetPin GP8, PWM
Print "Start"
For X = -120 to 120
   Servo 4, x
   Pause 2000
Next x
PWM 4, OFF
Print "STOP"
END
It also fails with a SYNTAX ERROR.
I'm starting to think the SERVO command is broken.
Has anyone else had any luck with it?
Posted: 12:42pm 23 Nov 2025
There is a typo in the manual. Should read
  Quote  ‘positionA’ and ‘positionB’ can be between -20 and 120 and will generate a
50Hz signal between 800uSec and 2.2mSec
So a value of 50 puts it in the middle.
Askjerry
Posted: 12:07am 29 Nov 2025
Well, that would make a difference... and the center-point or null for a continuous servo would then be...
(120 + 20) = 140 , half of that is 70... so 120-70 = 50
[ -20 ]----------[ 50 ]----------[ 120 ]
I'll give that a try tonight... thank you!
Jerry
