Local Time 09:42 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Request: Micromite Modbus CRC CFunction
Turbo46
Posted: 05:36am 02 Dec 2025
Hello All,
I would like to use the Modbus CRC in a Micromite MK2. I am aware of the MMBasic versions on The Fruit Of The Shed (I put them there) but I would like to use a CFunction for extra speed. I also Know that it is available in the PicoMite but I want to use the Micomite.
Claude AI has written the C code for me but I don't have the software or the knowledge to compile the code.
If there is someone out there who could do that for I would be very grateful.
The code:
* Modbus CRC-16 CFunction for Micromite Mk2 MMBasic
* Compile this with MPLAB X and XC32 compiler using the settings:
* - Position independent code (-mno-abicalls -fno-pic)
* - Optimization level -O1 or -O2
* - Target: PIC32MX470F512H (for Micromite Mk2)
* After compiling, extract the hex codes and insert into MMBasic as:
* CFunction modbus_crc(STRING) INTEGER
*   [hex codes here]
* End CFunction
* Usage in MMBasic:
*   data$ = CHR$(&h01) + CHR$(&h03) + CHR$(&h00) + CHR$(&h00) + CHR$(&h00) + CHR$(&h0A)
*   crc% = modbus_crc(data$)
*   PRINT "CRC: "; HEX$(crc%, 4)
#include "CFunction.h"
* Calculate Modbus CRC-16
* Input: Pointer to MMBasic string (first byte = length, followed by data)
* Returns: 16-bit CRC value as long long int
long long int modbus_crc(unsigned char *str) {
   unsigned char len;
   unsigned char *data;
   unsigned short crc;
   int i, j;
   // Get string length (first byte)
   len = *str;
   // Point to actual data (skip length byte)
   data = str + 1;
   // Initialize CRC to 0xFFFF
   crc = 0xFFFF;
   // Process each byte
   for (i = 0; i < len; i++) {
       crc = crc ^ data[i];
       // Process each bit
       for (j = 0; j < 8; j++) {
           if (crc & 0x0001) {
               crc = (crc >> 1) ^ 0xA001;
           } else {
               crc = crc >> 1;
   // Return as long long int (MMBasic integer type)
   return (long long int)crc;
* Example usage in MMBasic:
* ' Define the CFunction (after compiling and extracting hex codes)
*   00000000
*   [your hex codes here]
* End CFunction
* ' Use it in your program
* PRINT "CRC value: "; HEX$(crc%, 4)
* ' Append CRC to message (Modbus uses little-endian: low byte first)
* message$ = data$ + CHR$(crc% AND &hFF) + CHR$((crc% >> 8) AND &hFF)
* ' Send the complete message with CRC
* PRINT "Complete message with CRC: ";
* FOR i = 1 TO LEN(message$)
*   PRINT HEX$(ASC(MID$(message$, i, 1)), 2); " ";
* NEXT i
* PRINT
If someone can do it for me I will ask Geoff to include it in the documentation and/or put it on The Fruit Of The Shed.
Thank you in anticipation.
Bill
GerryL
Posted: 09:35pm 02 Dec 2025
Hi Bill,
try this, I have not tested it. Compiler set for -mprocessor=32MX470F512H. If it doesn't work let me know and I will look at it further.
CFUNCTION ModbusCRC
   00000000
    'main
   90870000 18E00012 3402FFFF 00803021 00873821 2405A001 90C30001 00431026
   24030008 30440001 10800003 00021042 00451026 3042FFFF 2463FFFF 1460FFFA
   30440001 24C60001 54C7FFF4 90C30001 03E00008 00001821
END CFUNCTION
Gerry
Turbo46
Posted: 04:10am 03 Dec 2025
Thank you Gerry,
That went well. I tested it with a few known MODBUS messages got the correct CRC each time.
' MODBUS CRC CFunction for the Micrmite Mk2 test and demo
CFUNCTION ModbusCRC
  00000000
END CFUNCTION
' Build the message
msg$ =  CHR$(01)+CHR$(03)+CHR$(00)+CHR$(00)+CHR$(00)+CHR$(02)
' Get the CRC
MBCRC% = ModbusCRC(msg$)
' Add the CRC to the message - reverse low byte and highbyte
msg$ = msg$ + chr$(MBCRC% and &HFF) + CHR$((MBCRC%>>8) and &HFF)
print "The message with CRC
printstr(msg$)
' Test the recieved message:
' The CRC of the message including the recieved CRC should be zero
print: print "Test a recieved message includind CRC"
print HEX$(MBCRC% = ModbusCRC(msg$) , 4); " Should be zero"
' Print a string as HEX numbers
sub PrintStr(b$)
for i = 1 to len(b$)
 print Hex$(asc(mid$(b$,i,1)),2); ", ";
next i
print
end sub
Very much appreciated.
Bill
