Local Time 05:46 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Ways to use a 24C32 EEPROM
Posted: 07:47am 15 Jan 2026
On the Firmware thread @JanVolk requested information on using the EEPROM on a RTC module.
If anyone has code they could share with him perhaps post it here rather than on the Firmware thread.
To get it started here are some Subs and Functions I did some time ago.
The 24C32 is organized in 32 byte pages.
Reading can ignore the page boundaries but writing wont cross a page boundary, instead wrapping back to the start of the page and replacing the original data.
These write and read page blocks. Not sure if they will be of any use, but am sure others have better code.
Function EEPROM.pageR$(EEPROM.addr As integer, page.no As Integer)
' Read a 32 bit page from a 24Cxx EEPROM to a String (hence R$)
'Usage Variable$ = EEPROM.pageR$(I2C address, page number)
 I2C OPEN 400, 100, PU
 I2C Write EEPROM.addr, 0, 2, page.no*32 >> 8, page.no*32 And 255
 I2C Read EEPROM.addr, 0, 32, EEPROM.pageR$
End Function
Sub EEPROM.pageWS(EEPROM.addr As integer, page.no As Integer, Dat$ As String, Offset As integer, Pad$)
' Write a 32 bit page to a 24Cxx EEPROM from a String (hence WS)
' Usage - EEPROM.pageWS(I2C address, String$to write [, offset from start of page] [,padding character])
' if specified Pad$ first character fills any remaining space at the end of the page, otherwise leave original data.
  Local D$
  If Offset > 31 Then Offset = 31
  D$ = Left$(Dat$,32-Offset) 'prevent wrapping to start of page if too long by truncating data
  If (Pad$ <> "") And (Len(D$) < (32 - Offset)) Then D$ = D$ + String$(32-Offset-Len(D$), Pad$)
  'if data is less than 32 bytes pad remainder with Pad$ - if Pad$ specified, otherwise leave original data.
  D$ = Chr$((page.no * 32 + Offset) >>8) + Chr$((page.no * 32 + Offset) And 255) + D$ 'prepend 2 pointer bytes to data
  I2C Write EEPROM.addr, 0, Len(D$), D$ : Pause 5
End Sub
Function EEPROM.GetAddr() As integer ' if more than one the last address is returned
' Find the I2C address of a 24Cxx EEPROM
  Local A
  For n=80 To 87 'find 24Cxx address
   I2C read n,0,1,A
   If Not MM.I2C Then
    EEPROM.GetAddr = n
'     Print "24Cxx I2C address ="; n 'show all the addresses found
'     Exit For 'un-REM this if you want the first one
   EndIf
  Next
End Function
Sub EEPROM.pageRA EEPROM.addr, page.no
' Read a 32 bit page from a 24Cxx EEPROM into a global array - DataArray() (hence RA)
' Usage - EEPROM.pageRA I2C address, page number
  On error skip 'prevent exit if array already exists
  Dim Integer DataArray(31) 'ensure array exists if not previously created
  I2C Read EEPROM.addr, 0, 32, DataArray()
End Sub
Sub EEPROM.pageWA EEPROM.addr As integer, page.no As Integer, DataArray%(), Offset As integer, Pad%
' Write a 32 bit page to a 24Cxx EEPROM from an Array (hence WA).
' Usage - EEPROM.pageWA I2C address,  Array to write, page.no [, offset = byte no in page.no to start writing]
' [,padding byte] (0 = no padding, use 256 to pad with 0)) - "Array", "page.no" and "offset" are BASE 0
' if specified  Pad% byte fills any remaining space at the end of the page, otherwise leave original data.
  BASE 0
  Local integer DAlength = 0, VE, n, D(33), OutLength
  D(0) = (page.no*32 + Offset) >> 8 : D(1) = (page.no*32 + Offset) And 255 'add pointer bytes
  For n=0 To 31-offset 'find the length of the data array (- offset to prevent wrap to start of page)
   On error skip
   D(n+2) = DataArray%(n)   'and load output array"
   DAlength = n
   If Pad% Then
     If MM.Errno Then D(n+2) = Pad%
    Else
     If MM.Errno Then Exit For
   EndIf
  Next
  OutLength = DAlength + 2
  If (Pad% > 0) And (DAlength < (32 - Offset)) Then  '(0 = no padding, use 256 to pad with 0))
' if data is less than 32 bytes pad remainder with Pad$ - if Pad% specified, otherwise leave original data.
    If Pad% > 255 Then Pad% = 0 'ensure only 1 byte
    OutLength = 34 - offset  'number of bytes to send - 2 pointer bytes + data + padding
    For n = OutLength To 33  'Add the padding bytes
      D(n) = Pad%
    Next
  EndIf
  I2C Write EEPROM.addr, 0, OutLength, D() : Pause 5 ' send the data to the EEPROM
End Sub
Sub Str2Array in$ 'Convert a string to a 32 max. element array - DataArray(max 31)
  On error skip
  Erase DataArray()
  Local n%, L% = Len(in$), addr%
  If L% > 32 Then L% = 32
  Dim integer DataArray(L% - 1) ': Print Len(in$),L%
  For n% = 1 To L%
   'DataArray(n%-1) = Asc(Mid$(in$,n%,1)) ':Print DataArray(n%-1);
    DataArray(n%-1) = Peek(BYTE Peek(VARADDR in$)+n%) ':Print DataArray(n%-1);
  Next
End Sub
Function Array2Str(InArray() As integer) As String 'Convert DataArray() of Bytes to a string, 32 chatacters max.
  Local n%
  For n% = 0 To 31
   On error skip
   Array2Str = Array2Str+Chr$(InArray(n%))
   If MM.Errno Then n% = 31
  Next
End Function
ville56
Posted: 04:03pm 17 Jan 2026
found my old code, reworked it a little. Can save/restore integer, float and string to/from eeprom. Will check later if I can it make work with structures as well.
24C32-var.zip
Gerald
73 de OE1HGA, Gerald
JanVolk
Posted: 10:29pm 17 Jan 2026
Thanks for these programs.
As I mentioned before, I need a simple sub to store a number of numbers (22) in an EEPROM and retrieve them later.
This is for a backup after a power outage for a climate control system. This process needs to restart with the correct parameters after a reboot, and the program first checks if there is data in the EEPROM.
If there is no data in the EEPROM, the program places a standard list in the EEPROM, retrieves this data, and starts processing it.
If there is data in the EEPROM, the program processes it.
The data is refreshed once a day at a quiet time, such as night.
You can also manually perform an update from the program if, for example, you've adjusted control parameters or offsets that you, as the customer, don't need to worry about, but are important for proper configuration.
I don't perform a backup for every change due to the limitations of writing to EEPROM or flash memory.
This could, of course, also be done with flash memory, but then an update wouldn't erase these values. Alternatively, an SD card can be used as a backup, making it easy for the customer to replace in the event of a defect, with the necessary notifications that the card has been changed.
An offset list can be left behind if needed.
If you have any other ideas for a solution for this backup, please feel free to post them here.
Jan.
ville56
Posted: 08:34am 18 Jan 2026
Jan, if e.g.
stat = put_f_eep(test_f, 32)        'store value
stat = get_f_eep(test_f, 32)        'retrieve value
is simple enough to store/retrieve the FLOAT variable "test_f" in location 32 on eeprom then you should be able to what you want to do with the routines I uploaded. The routines themself are a bit more complicated as the eeproms are a bit complicated as far as writing to them is concerned. The calls for the other dataypes are just the same. Just give it a try
And I just saw that the 3rd formal parameter in the call interface (eep_i2c_addr) is not necessary anymore, forgot to remove it when I changed it last time. But you can leave it as it is of course.
Gerald
Posted: 11:53am 18 Jan 2026
Some threads with EEPROM code.
https://www.thebackshed.com/forum/ViewTopic.php?TID=6917&PID=102879#102879
https://www.thebackshed.com/forum/ViewTopic.php?TID=12536&PID=152332#152332
