Local Time 05:45 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM/MMBASIC on generic STM32H743 board
fred777
Posted: 01:00pm 17 Jan 2026
Hi all,
I have some Leftover generic STM32H743 boards from another project.
They have 32MB of SDRAM. Is there any chance it could run the CMMs basic?
VGA etc. not needed, just using the usart1 serial port would be enough to start with.
PhenixRising
Posted: 02:21pm 17 Jan 2026
This won't work for you?
Edited 2026-01-18 00:24 by PhenixRising
Posted: 02:38pm 17 Jan 2026
It's a supported CPU, so that's a good start.
Compare the SDRAM address and peripherals with those on the supported boards - if they're the same it should work.
If not, can you rebuild the code?  If not, that's probably an end to it.
BTW you can easily program your board with the current firmware in case you want to see what happens.  You can't "brick" these chips by loading wrong code.
Edited 2026-01-18 00:39 by JohnS
fred777
Posted: 05:19pm 17 Jan 2026
Thanks guys, I was totally unaware of the armmite version of mmbasic. I’ll start testing  asap.
Although I’m guessing no ltdc(vga) or fmc(sdram) in the armmite version.
Still, lots to try out!
Cheers!
Edited 2026-01-18 03:34 by fred777
