Local Time 04:40 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Connecting stepper motors
PilotPirx
Posted: 08:24am 04 Feb 2026
Hello,
with the new firmware V6.02.00, stepper motors can also be controlled (up to 3).
There is also a separate PDF for the software. But how do I connect them electrically and what are the preferred pins?
I would like to connect two steppers. Which drivers do I need and how are they connected?
I would be grateful for any help.
dddns
Posted: 09:55am 04 Feb 2026
It supports stepper drivers which are based on step/dir input:
STEPPER AXIS axis, step_pin, dir_pin [, enable_pin] [, dir_invert] [, steps_per_mm] [,
max_vel] [, max_accel]
All of these should work with MMBasic together with e.g. these motors
Pollin
Edited 2026-02-04 20:00 by dddns
