Local Time 03:46 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: How many COM ports
PhenixRising
Posted: 04:51pm 11 Feb 2026
Available on the expansion header?
Posted: 05:18pm 11 Feb 2026
Both of them. :)
pin 8 - com1 tx
pin 10 - com1 rx
pin 16 - com 2 tx
pin 11 - com 2 rx
PhenixRising
Posted: 08:23pm 11 Feb 2026
[Homer Simpson voice] DOH!!! It's right there on geoffg.net 😁
But cheers, Mick 👍😎👍
PhenixRising
Posted: 09:40pm 11 Feb 2026
Mick, just so you know....I have more of a comprehension issue than you do. You're a  veritable MM-database.
Now I just need a simple yay or nay; Is there no way for my CMM2 to boot into a program with no SD present?
This is my only hesitation for using this product.
Posted: 07:55am 12 Feb 2026
Yes, but not in the same way as the Pico. It likes to be a bit different. :)
OPTION FLASH [n]
specifies that the program will run from flash, not RAM. n sets the program start position so you can have multiple programs stored in flash.
OPTION RAM
specifies that the program will run from RAM, not flash.
OPTION AUTORUN ON/OFF
If the CMM2 is set to run programs from flash this runs the current program that's in flash on power up or on a restart. It is switched off by NEW.
If the CMM2 is set to run programs from RAM then this looks for AUTORUN.BAS on the SD card and runs it.
I can recommend the CMM2, it's a beast! I only have the G1 version though.
