Local Time 00:18 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : psram gone help if run out of Heap memory
tenij000
Posted: 04:51am 14 Mar 2026
was gone try to add text for cells but then i run out of Heap memory
' PICO-SPREADSHEET V1.7 (FULL VERSION)
' Functies: Auto-Grid, Formulegeheugen, Save/Load, Anti-Crash
CLS
DIM cells(26, 20)
DIM formulas$(26, 20)
fileName$ = "spreadsheet.csv"
' Startscherm met raster
GOSUB ShowGrid
DO
 ' De input verschijnt altijd onder het raster
 INPUT "Opdracht: ", cmd$
 cmd$ = UCASE$(cmd$)
 IF cmd$ = "EXIT" THEN END
 SELECT CASE cmd$
   CASE "CLEAR"
     FOR r = 1 TO 20: FOR c = 1 TO 26
       cells(c, r) = 0: formulas$(c, r) = ""
     NEXT c: NEXT r
     GOSUB ShowGrid
     PRINT ">> Alles gewist."
   CASE "SHOW"
     GOSUB ToonLijst
   CASE "SAVE"
     GOSUB OpslaanBestand
     GOSUB ShowGrid
     PRINT ">> Opgesl*gen in "; fileName$
   CASE "LOAD"
     GOSUB LadenBestand
     RecalculateAll
     GOSUB ShowGrid
     PRINT ">> Bestand geladen."
   CASE "HELP"
     GOSUB ToonHelp
   CASE ELSE
     ' Standaard: Verwerk de formule en ververs het grid
     GOSUB VerwerkFormule
     GOSUB ShowGrid
 END SELECT
LOOP
' --- RASTER WEERGAVE (MET SLIMME KLEUR-DETECTIE) ---
ShowGrid:
 LOCAL col, row, cVal, cStr$, pad, f$, isFormule, i, charCode
 CLS
 ' Print de kolomletters (A t/m E) in geel
 COLOR RGB(YELLOW), RGB(BLACK)
 PRINT "      ";
 FOR col = 1 TO 5
   PRINT "|    " + CHR$(64 + col) + "      ";
 NEXT col
 PRINT "|"
 COLOR RGB(WHITE), RGB(BLACK)
 PRINT "------" + STRING$(60, "-")
 ' Loop door de rijen (1 t/m 10)
 FOR row = 1 TO 10
   IF row < 10 THEN PRINT " ";
   PRINT STR$(row) + "   ";
   FOR col = 1 TO 5
     cVal = cells(col, row)
     cStr$ = CleanString$(STR$(cVal))
     f$ = formulas$(col, row)
     isFormule = 0
     ' --- CHECK: Is dit een berekening of verwijzing? ---
     ' 1. Check op wiskundige tekens
     IF INSTR(f$, "+") > 0 OR INSTR(f$,"-") > 0 OR INSTR(f$,"*") > 0 OR INSTR(f$,"/") > 0 THEN
       isFormule = 1
     ENDIF
     ' 2. Check op letters (celverwijzingen zoals A1, B2)
     FOR i = 1 TO LEN(f$)
       charCode = ASC(MID$(f$, i, 1))
       IF charCode >= 65 AND charCode <= 90 THEN isFormule = 1
     NEXT i
     ' Teken de cel-afscheiding in wit
     PRINT "| ";
     ' Bepaal de kleur van de waarde
     IF isFormule = 1 THEN
       COLOR RGB(CYAN), RGB(BLACK)   ' Formules/Sommen in Cyaan
     ELSE
       COLOR RGB(WHITE), RGB(BLACK)  ' Gewone getallen in Wit
     ENDIF
     PRINT cStr$;
     ' Vul de rest van de kolombreedte op met spaties (in wit)
     pad = 10 - LEN(cStr$)
     IF pad > 0 THEN PRINT STRING$(pad, " ");
   NEXT col
   PRINT "|"
 NEXT row
 PRINT "Typ HELP voor info. Opdracht (bijv. A1=B1+5):"
RETURN
' --- SUBROUTINES ---
ToonLijst:
 PRINT "--- ACTIEVE FORMULES ---"
 LOCAL fnd, rL, cL
 fnd = 0
 FOR rL = 1 TO 20: FOR cL = 1 TO 26
   IF formulas$(cL, rL) <> "" THEN
     PRINT CHR$(64 + cL); rL; " = "; formulas$(cL, rL)
     fnd = 1
   ENDIF
 NEXT cL: NEXT rL
 IF fnd = 0 THEN PRINT "(Geen formules gevonden)"
RETURN
ToonHelp:
 PRINT "--- HELP OVERZICHT ---"
 PRINT "A1=10       : Getal invoeren"
 PRINT "B1=A1*2.5   : Formule invoeren"
 PRINT "SHOW        : Lijst met alle formules"
 PRINT "SAVE / LOAD : Bestand op de Pico opslaan/laden"
 PRINT "CLEAR       : Alles wissen"
 PRINT "EXIT        : Programma stoppen"
 PRINT "Druk op Enter om terug te gaan..."
 INPUT dummy$
 GOSUB ShowGrid
RETURN
VerwerkFormule:
 LOCAL pPos, tR$, fR$, t$, f$, cX, rY
 pPos = INSTR(cmd$, "=")
 IF pPos > 0 THEN
   tR$ = LEFT$(cmd$, pPos - 1): fR$ = MID$(cmd$, pPos + 1)
   t$ = CleanString$(tR$): f$ = CleanString$(fR$)
   ' Controleer op zelf-verwijzing
   IF INSTR(f$, t$) > 0 THEN
     PRINT "!! Fout: Circulaire referentie!"
     PAUSE 2000
   ELSE
     ' Adres bepalen
     cX = ASC(LEFT$(t$, 1)) - 64
     rY = VAL(MID$(t$, 2))
     IF cX > 0 AND cX < 27 AND rY > 0 AND rY < 21 THEN
       formulas$(cX, rY) = f$
       RecalculateAll
     ELSE
       PRINT "!! Fout: Ongeldig cel-adres!"
       PAUSE 1500
     ENDIF
   ENDIF
 ENDIF
RETURN
OpslaanBestand:
 OPEN fileName$ FOR OUTPUT AS #1
 LOCAL rS, cS
 FOR rS = 1 TO 20: FOR cS = 1 TO 26
   IF formulas$(cS, rS) <> "" THEN
     PRINT #1, CHR$(64 + cS); rS; ","; formulas$(cS, rS)
   ENDIF
 NEXT cS: NEXT rS
 CLOSE #1
RETURN
LadenBestand:
 LOCAL rD, cD, kommaPos, rgl$, cl$, fr$
 ' Wissen voor het laden
 FOR rD = 1 TO 20: FOR cD = 1 TO 26: formulas$(cD, rD) = "": NEXT cD: NEXT rD
 OPEN fileName$ FOR INPUT AS #1
 DO WHILE NOT EOF(#1)
   LINE INPUT #1, rgl$
   kommaPos = INSTR(rgl$, ",")
   IF kommaPos > 0 THEN
     cl$ = LEFT$(rgl$, kommaPos - 1): fr$ = MID$(rgl$, kommaPos + 1)
     cX = ASC(LEFT$(cl$, 1)) - 64: rY = VAL(MID$(cl$, 2))
     formulas$(cX, rY) = fr$
   ENDIF
 LOOP
 CLOSE #1
RETURN
' --- REKEN ENGINE (SUB & FUNCTIONS) ---
SUB RecalculateAll
 LOCAL c, r, fStr$, fV$
 ' Twee passes om kettingreacties (C=B, B=A) op te vangen
 FOR pass = 1 TO 2
     fStr$ = formulas$(c, r)
     IF fStr$ <> "" THEN
       fV$ = ParseFormula$(fStr$)
       cells(c, r) = EVAL(fV$)
     ENDIF
   NEXT c: NEXT r
 NEXT pass
END SUB
FUNCTION CleanString$(in$)
 LOCAL i, ch$, rs$
 rs$ = ""
 FOR i = 1 TO LEN(in$): ch$ = MID$(in$, i, 1)
   IF ch$ <> " " THEN rs$ = rs$ + ch$
 NEXT i
 CleanString$ = rs$
END FUNCTION
FUNCTION ParseFormula$(f$)
 LOCAL c, r, cn$, oStr$, vStr$
 oStr$ = f$
 ' Terugwaarts zoeken voorkomt dat A10 wordt gezien als A1 + "0"
 FOR c = 26 TO 1 STEP -1: FOR r = 20 TO 1 STEP -1
   cn$ = CHR$(64 + c) + CleanString$(STR$(r))
   IF INSTR(oStr$, cn$) > 0 THEN
     vStr$ = STR$(cells(c, r))
     oStr$ = ReplaceCell$(oStr$, cn$, vStr$)
   ENDIF
 NEXT r: NEXT c
 ParseFormula$ = oStr$
END FUNCTION
FUNCTION ReplaceCell$(br$, ou$, ni$)
 LOCAL p, res$
 res$ = br$: p = INSTR(res$, ou$)
 DO WHILE p > 0
   res$ = LEFT$(res$, p - 1) + ni$ + MID$(res$, p + LEN(ou$))
 LOOP
 ReplaceCell$ = res$
END FUNCTION
some times on the internet i see pico whit this 16mb extra memmory that gone help
Posted: 04:22pm 14 Mar 2026
Peter and others have said that PSRAM will help with heap issues. I am awaiting gear to test.
Meanwhile, there's this statement: DIM formulas$(26, 20)
String arrays allocate 255 bytes per element. You can free up lots of heap by adding LENGTH.
For instance:
DIM formulas$(26, 20) LENGTH 20
(or whatever length is appropriate)
Strings which are not arrays also allocate 255 bytes, but Peter found a way to alleviate that for strings less than 8 bytes, so
Dim SomeShortString$="Example" Length 7
will save you 148 bytes.
Edited 2026-03-15 02:25 by lizby
tenij000
Posted: 04:27pm 14 Mar 2026
WeAct RP2350A_V20 Completely replace the original PICO2 Raspberry Pi RP2350 RISC-V Hazard3 520KByte SRAM 4or16MByte QSPI Flas
maby this can work like 8euro
Posted: 04:58pm 14 Mar 2026
I had thought that module might work, but Mixtes90 pointed out that the QSPI memory is flash, not PSRAM.
Have you tried putting LENGTH on your string array?
Posted: 05:05pm 14 Mar 2026
Note: It doesn't have PSRAM. It's a "look alike" Pico 2 but with the option of more flash. That will make A:/ bigger.
If you want a module in the same footprint as a Pico 2 but with PSRAM then I think there's only the Pimorini Pico Plus 2, which costs appreciably more.
There are other alternatives if you aren't looking for the same footprint.
Edited 2026-03-15 03:06 by Mixtel90
tenij000
Posted: 12:29am 15 Mar 2026
for now the program works whit out the  LENGTH on string array
for now works kind of line multiplan   but
gone thake look at that  Pimoroni Pico Plus 2
Posted: 03:22am 15 Mar 2026
Glad you got it working, but if you didn't add a length to DIM formulas$(26, 20), you really should.
DIM formulas$(26, 20) ' takes 26*20*255 characters -> 132,600 bytes
But
DIM formulas$(26, 20) LENGTH 31 ' takes 16,120
