Local Time 22:36 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : High speed dual PicoMite memory sharing
Posted: 08:20am 01 Apr 2026
Since single PicoMite firmware is now pretty much complete I though it would be fun to look at connecting PicoMites together. Attached is some experimental firmware for the RP2350 VGA and the RP2040VGA.
To run the code you need to connect two PicoMites together with 9 GPIO lines + GND. I recommend using GP0-GP7 for the data and GP22 for the clock as per the test program below.
Run the host program on one PicoMite and the client on the other. Doesn't matter which order. You will see the GUI TEST pattern running on the host magically appear on the clients VGA display. Note, All this code runs in the background under PIO/DMA control without any processor involvement. To stop and rerun you must first close the background activity using MEMORY SHARE STOP
Note that with two PicoMites running at 252MHz the data trasfer rate is  84 Mbytes/second
Note also: that the client PicoMite is fully usable at the command prompt even though its display is being written by the host.
Finally note: The HOST and CLIENT commands are blocking until the synchonisation has happened. After that everything takes place in the backgound
PicoMiteVGAEXP.zip
Client code
' ShareClient.bas - MEMORY SHARE CLIENT test program
' Runs on RP2040 PicoMite VGA (PIO1 available)
' Wiring (directly between two Picos):
'   Host GP0-GP7  --> Client GP0-GP7   (8 data lines)
'   Host GP22      --- Client GP22       (shared clock)
'   GND           --- GND
' Either host or client can be started first - handshake is automatic.
MODE 2
Dim addr% = MM.Info(writebuff)
Print "MEMORY SHARE CLIENT Test"
Print "Shared buffer at address: &h" Hex$(addr%)
Print "Buffer size: 38400 bytes (100 integers)"
Print
' Start receiving: PIO 1, SM 0, data GP0, clock GP22, address, 38400 bytes
' Note: client clock pin (GP22) connects to host clock pin (GP22) via wire
Memory Share Client 1, 0, GP0, GP22, addr%, 38400
End
Host code:
' ShareHost.bas - MEMORY SHARE HOST test program
'   GND           --- GND
MODE 2
Print "MEMORY SHARE HOST Test"
Print "Buffer size: 38400 bytes"
Print
' Start sharing: PIO 1, SM 0, data GP0, clock GP22, address, 38400 bytes, clk_div 3
Memory Share Host 1, 0, GP0, GP22, addr%, 38400, 3
GUI test lcdpanel
End
MEMORY_SHARE_User_Manual.pdf
Edited 2026-04-01 19:13 by matherp
Plasmamac
Posted: 10:23am 01 Apr 2026
Like the Idea
Plasma
bfwolf
Posted: 12:20pm 01 Apr 2026
Nice feature.. What use-cases did you have in mind? Sharing e.g. the screen-buffer and have "dual-screen" this way? Or 1 Pico for measurements and GUI and an other for networking?
Posted: 12:26pm 01 Apr 2026
Lots of possibilities. The demo would allow dual screen by exporting a framebuffer over the link and having the local display with something else on it. So far it is just a proof of concept. Getting the synchronisation to work was the challenge.
PhenixRising
Posted: 01:28pm 01 Apr 2026
Holy heck
But limited to two devices, right?
bfwolf
Posted: 03:32pm 01 Apr 2026
The downside is that you have to "sacrifice" 8+1 GPIOs.
Couldn't this also work with 4+1 GPIOs, like with QSPI?
Perhaps make it selectable as a parameter at the end of 'MEMORY SHARE HOST/CLIENT'?
The data rate is high enough that real-time video transmission would be possible – presumably even with 4 data bits.
Additional question: Can one pico be both HOST and CLIENT simultaneously? Of course, with separate lines! Then duplexing or "daisy-chaining" across multiple picos would be possible.
mozzie
Posted: 05:00pm 01 Apr 2026
G'day Peter,
Very interesting idea, the grey matter is already churning with possibilities...
If you are exploring connecting PicoMites together, would you consider the following for less demanding applications?
We have the standard PicoMite with USB, and we have USB PicoMites with a USB host, and the Tiny USB firmware is able to work with CDC. If a serial link was possible across this USB link we could have all the pins of both picomites accessible while we swap data between them.
This also makes dataloggers and keypads / gamepads / CNC possible by just plugging in a USB cable.
This has been on my wish list since the USB firmware was first announced.
Many thanks once again.
Lyle.
PhenixRising
Posted: 06:17pm 01 Apr 2026
FWIW, I have always liked the Round-Robin method: Scalable, only two pins, read/write:
High Speed Prop to Prop.zip
BeauNET Test Code.zip
Posted: 07:33pm 01 Apr 2026
Round-robin works fine but it's asynchronous and therefore inefficient. Efficiency gets even worse as the number of nodes increases. If processor n sends a packet to processor n-1 the packet has to go round the complete loop, yet from n-1 to n it's almost instantaneous. For better efficiency you really need a common clock signal as well as a data line between each node, otherwise the clock has to be extracted from the data stream in real time. Synchronous operation also allows multiple packets on the ring without collisions.
I2C, even though the clock speed may be lower, can sometimes give much faster data transfer as packets go directly to any node on the system, rather than having to be passed round. You do have the collision problem though on multi-master systems.
PhenixRising
Posted: 08:30pm 01 Apr 2026
I was gonna calculate but I always get something wrong
But the above, on a 20MIPS processor (80MHz, 4 clocks/instruction) achieves 8.42Mb/s.
What would the Pico achieve,do you think?
BASIC command execution granularity, ~5µS?
Only guessing
bfwolf
Posted: 08:52pm 01 Apr 2026
  PhenixRising said  FWIW, I have always liked the Round-Robin method: Scalable, only two pins, read/write: ...
RS485 works well as an interface between two or more computers, and is also very fast (with high bit rates) over long distances. Ethernet 10bast-T uses essentially the same physics for transmission (differential signals) over the line. RS485 can also be multi-master (with token passing or CSMA/CD). Many USARTs support a 9-bit mode, where the parity bit can be used to distinguish between address and data bytes.
PhenixRising
Posted: 09:37pm 01 Apr 2026
I have been using 4-wire (full duplex) RS485 for many years. Never had a single glitch, no checksum errors, nothing. Only 230KBAUD over 15 metres, though.
bfwolf
Posted: 10:03pm 01 Apr 2026
Found an interesting page about RS485:
https://resources.altium.com/p/serial-communications-protocols-rs-485
About max. data rates there:
So over 1000m allowed at 0.230Mbps and 20m at 20Mbps !!!
(If suitable cables are used and correct termination is ensured)
PhenixRising
Posted: 10:39pm 01 Apr 2026
I'm waiting for an excuse to try this
IanT
Posted: 09:01am 02 Apr 2026
When I saw the title of Peter's post yesterday, I initially thought it was going to be an April Fools
Just keep getting suprised (in fact amazed) by what's happening here...
IanT
PhenixRising
Posted: 09:53am 02 Apr 2026
Ditto. Definitely the most exciting development in the MCU world and with documentation that is second to none
