Forum Index : Microcontroller and PC projects : WEB Connect from program
| terekgabor Senior Member Joined: 02/01/2026 Location: HungaryPosts: 155 |
Hello! Is there any way to solve possibility connecting wifi from program? WEB CONNECT only works from command line. But WEB SCAN is working from program. Not logic why, because I can’t connect from program. Thx, G@bor |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9238 |
I thought it did - providing you have set OPTION WIFI up. I've not played with one of these for ages. It might not if you haven't set OPTION WIFI as your password would have to be in the clear text MMBasic program. Only guessing. Mick Zilog Inside! nascom.info for Nascom & Gemini |
If I use WEB CONNECT ssid, pswd in a program I got Invalid in a program error. Can be good if I can connect to a wifi network choosing it in my program for example. G@bor |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12056 |
You can't do it in a program. Like your PC, you connect to a wifi network and then you use whatever application. You can't choose a wifi network inside Excel. This functionality isn't going to change |
Okay! Thanks, I will do in this way! |
