Local Time 21:55 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RP2350-PIZERO del Waveshare.
Fede
Posted: 04:42pm 14 Apr 2026
Hello.
Is it possible to configure an RP2350-PiZero to run MMBasic and use its built-in HDMI and USB ports?
I've read the manual extensively but can't find where to configure the GP settings for HDMI.
I've only found OPTION HDMI PINS, but I don't think that's the right one.
Thank you very much.
https://www.waveshare.com/wiki/RP2350-PiZero#Overview
https://minibots.wordpress.com/2025/09/09/waveshare-rp2350-pizero/
Posted: 04:49pm 14 Apr 2026
No: they use the wrong pins for the DVI output. PicoMite uses the HSTX peripheral to generate DVI and this is fixed on pins gp12-gp19
Fede
Posted: 05:06pm 14 Apr 2026
Oh.
Thank you so much for the quick response.
I'll try using it like a regular 2350.
fred777
Posted: 05:47am 19 Apr 2026
Its a real shame about the HDMI pins,
Could have been a nice board otherwise.
At least PSRAM works and it seems to be stable
at max cpu clock
Posted: 06:33am 19 Apr 2026
There's nothing to stop you from using its HDMI output socket with some external resistors to get a VGA display. Alternatively you could use the connections as GPIO pins or use some as an SPI port to feed a LCD display.
It's just a pity that they crippled it by not using the HSTX port for anything useful.
fred777
Posted: 04:42pm 20 Apr 2026
  fred777 said  Its a real shame about the HDMI pins,
at max cpu clock
Correction, mine seems to max out @320Mhz, any higher and it sporadically hangs...
Posted: 06:00pm 20 Apr 2026
Erm...
"Max CPU clock" is 150MHz. Any faster than that is overclocking and isn't supported on the RP2350A or B.  ;) The module probably passes or exceeds every performance test for the RP2350 / Pico 2 with PSRAM.
If one will go any faster it's a happy bonus. :)
