Local Time 20:13 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Is it possible to ‘backup’ everything in a PicoMite into a single file
Posted: 01:35pm 24 Apr 2026
Probably a question for Peter, but will ask here hoping someone else may have some experience.
I have an almost finished product that is based around a PicoMite (standard RP2350 firmware). Throughout development, I updated the firmware (typically to test Peter’s latest set of ‘goodies’), and OPTIONs were tweaked as I adjusted things. I also have a data file stored in the built-in flash drive that is used by my code.
If I were to build another unit, then I would manually do the following:
1. Nuke Pico
2. Load standard RP2350 firmware (.uf2)
3. Configure OPTIONs manually (TeraTerm into Pico)
4. Load data-file into Pico (TeraTerm)
5. Save data file to drive A:
6. Load program code into Pico (TeraTerm)
7. RUN program…..
Doing this as a one-off is fine, but the question is to ask if there is any way to take a ‘snapshot’ of everything in a configured Pico, generate a single file (.uf2?), and then simply load that into a ‘blank’ Pico so that everything is ‘pre-configured’.
Hope this makes sense; and appreciate any help pointing me towards a solution……
karlelch
Posted: 01:43pm 24 Apr 2026
Hi WhiteWizzard
Some time ago, I wrote a Python tool („picom“) to backup and restore a picomite installation. It saves everything in a folder on the connected PC (not a single file, though). I use it for my projects, maybe you want to have a look.
https://github.com/teuler/picom
Best
Thomas
Posted: 01:53pm 24 Apr 2026
I haven't done it but Geoff certainly has and it is definitely doable to create a uf2 ready to go.
Posted: 01:57pm 24 Apr 2026
Thanks Peter. I think I may have read something in his original Pico game console about this so will have a look when back home.
Maybe Geoff can steer me on this if he sees this thread.
Frank N. Furter
Posted: 04:47pm 24 Apr 2026
We used to have a program here that allowed you to read out an RP2040 and use it to generate a uf2 file.
I'm not sure if that works with a RP2350, though...
Frank
toml_12953
Posted: 06:48pm 24 Apr 2026
  karlelch said  Hi WhiteWizzard
Best
Thomas
I got no errors in any of the install steps.
Even though I did the pip install pyserial and even tried pip install serial,
I get
ModuleNotFoundError: No module named 'serial'
I use Win 11.
Footnote added 2026-04-25 05:27 by toml_12953
Ignore the above. I got out of PowerShell and back in then all the modules loaded properly.
The list of serial ports only lists 5 although it finds 14. No big deal since the PicoCalc is always on COM5.
I kept editing picom.py and not getting anything to work. Finally I saw that I have to change picom.toml to actually change the parameters. Everything works, now.
picom.toml is an easy name for me to remember.
Tom Lake
ebbandflow
Posted: 07:45pm 24 Apr 2026
I have not tried this (yet) but I read about picotool here:
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=18048
toml_12953
Posted: 08:05pm 24 Apr 2026
Best
Thomas
I'm getting close but now I get this (I'm showing just the first part):
PicoM v0.1.9 (beta)
 Save options to "202604241532.opt" file ...
 Save library, if exists, to `202604241532.lib` ...
Retrieving file tree from `B:` :
 Parsing `B:/` ...
Warning: Entry #0 (`B:/`) not recognized.
Warning: Entry #1 (`ine.mp3`) not recognized.
Warning: Entry #4 (`s`) not recognized.
Warning: Entry #6 (`bas`) not recognized.
Warning: Entry #8 (`e_johnybot.nes`) not recognized.
Warning: Entry #11 (`as`) not recognized.
Warning: Entry #13 (`as`) not recognized.
Warning: Entry #14 (`11:47 22-04-2026        383  Going Up.b`) not recognized.
Warning: Entry #15 (`as`) not recognized.
Warning: Entry #19 (`s`) not recognized.
Warning: Entry #21 (`as`) not recognized.
Warning: Entry #23 (`txt`) not recognized.
13:59 27-11-2023       2408  Lemmings.t`) not recognized.
Warning: Entry #25 (`xt`) not recognized.
Warning: Entry #29 (`Test.bas`) not recognized.
Warning: Entry #35 (`s`) not recognized.
Warning: Entry #39 (`mp`) not recognized.
Warning: Entry #41 (`as`) not recognized.
23:22 10-06-2025        135  savage.bas`) not recognized.
Warning: Entry #51 (`.bas`) not recognized.
Warning: Entry #53 (`02R.bas`) not recognized.
Warning: Entry #55 (`.bas`) not recognized.
Warning: Entry #57 (`bas`) not recognized.
Warning: Entry #60 (`s.txt`) not recognized.
Posted: 10:40pm 24 Apr 2026
This describes how I do it: Instructions.pdf
Posted: 06:00am 25 Apr 2026
Many-Thanks for all the replies.
Geoff - I will try following your clear instructions to generate an .uf2 file over the weekend; hopefully it will work for me here and generate what is needed.
Thanks again.
Posted: 06:27am 25 Apr 2026
  Quote  hopefully it will work
Geoff's "clear instructions" are exactly that. Worked first try.
Worth including in the "Extra Documentation" folder.
Edited 2026-04-25 16:30 by phil99
karlelch
Posted: 04:46pm 25 Apr 2026
Hi WhiteWizzard,
glad you found a solution with the uf2 files. Sorry for the trouble with picom.
I updated picom (v0.1.11) and tested it for my use case but not with b:\ as my systems usually don't have an SD card ... I will look into that in the future.
Best
Thomas
toml_12953
Posted: 03:46am 26 Apr 2026
Best
Thomas
Even the 0.1.11 version seems to have a problem with subdirectories. It thinks many (but not all) files are in a different subdirectory than they actually are. The ft (filetree) command shows many files under the wrong subdirectory and the backup command can't find those files.
EDNEDN
Posted: 04:14am 26 Apr 2026
You are better off using PicoTools and generating a .UF2 to save your installation.    I use a similar sequence of commands that Geoffg's instructions describe to backup a PicoMite all the time.   You can take a snap shot of everything in your Pico and either restore that Pico back to that state or clone that Pico unto another Pico.
It is a very clean and reliable way to get everything in the Pico.
Edited 2026-04-26 14:14 by EDNEDN
karlelch
Posted: 05:51am 26 Apr 2026
  toml_12953 said  Even the 0.1.11 version seems to have a problem with subdirectories. It thinks many (but not all) files are in a different subdirectory than they actually are. The ft (filetree) command shows many files under the wrong subdirectory and the backup command can't find those files.
Hi toml_12953,
could you give me an example? On A: I have not problems with directories (see below).
In any case, as I said before, the uf2 solution seems ideal for WhiteWizzard's use case. I often want to change the firmware - trying out the latest versions - and then want to make a backup that I can restore after the firmware update.
Best
Thomas
Restore:
(picom) PS F:\Dropbox\__GIT\picom> python picom.py -t -s "COM5" -n ".\miiha_202604251745\" r
PicoM v0.1.11 (beta)
# Getting command line arguments ... done.
Trying to kill open terminal ...
# Checking for PicoMite ... done.
Retrieving key data from PicoMite ....... done.
# Check drive ...
# Locate backup ...
Retrieving file tree from `F:\Dropbox\__GIT\picom\miiha_202604251745` :
 Parsing `F:\Dropbox\__GIT\picom\miiha_202604251745` ...
 Parsing `F:\Dropbox\__GIT\picom\miiha_202604251745\vl53l5cx` ...
 Parsing `F:\Dropbox\__GIT\picom\miiha_202604251745\vl53l5cx\sub2` ...
 Parsing `F:\Dropbox\__GIT\picom\miiha_202604251745\vl53l5cx\sub_directory` ...
 Parsing `F:\Dropbox\__GIT\picom\miiha_202604251745\vl53l5cx\sub2\sub3` ...
13 file(s) and 4 folder(s) found.
Restoring backup `F:\Dropbox\__GIT\picom\miiha_202604251745` to `PicoMite` @`COM5` :
Continue (y/n)? y
Kill everything on drive `A:` (y/n)? y
 Formatting drive `A:` ...
# Sending `drive "A:/FORMAT"` ...
# `.fm` : Size: 128 bytes (= 1 packages)
# Send `xmodem receive ".fm"` ...
Restore [==================================================] 100% `.fm` - complete (128 of 128 bytes).
# `202604251745.lib` : Size: 26368 bytes (= 206 packages)
# Send `xmodem receive "202604251745.lib"` ...
Restore [==================================================] 100% `202604251745.lib` - complete (26368 of 26368 bytes).
# `bootcount` : Size: 128 bytes (= 1 packages)
# Send `xmodem receive "bootcount"` ...
Restore [==================================================] 100% `bootcount` - complete (128 of 128 bytes).
# `lib_vl53.bas` : Size: 40192 bytes (= 314 packages)
# Send `xmodem receive "lib_vl53.bas"` ...
Restore [==================================================] 100% `lib_vl53.bas` - complete (40192 of 40192 bytes).
# `miiha.bas` : Size: 32896 bytes (= 257 packages)
# Send `xmodem receive "miiha.bas"` ...
Restore [==================================================] 100% `miiha.bas` - complete (32896 of 32896 bytes).
# `tof.dat` : Size: 2048 bytes (= 16 packages)
# Send `xmodem receive "tof.dat"` ...
Restore [==================================================] 100% `tof.dat` - complete (2048 of 2048 bytes).
Make folder `vl53l5cx` ...
# Send `mkdir "vl53l5cx"` ...
# `vl53l5cx/firmware.bin` : Size: 86016 bytes (= 672 packages)
# Send `xmodem receive "vl53l5cx/firmware.bin"` ...
Restore [==================================================] 100% `vl53l5cx/firmware.bin` - complete (86016 of 86016 bytes).
# `vl53l5cx/nvm_cmd.bin` : Size: 128 bytes (= 1 packages)
# Send `xmodem receive "vl53l5cx/nvm_cmd.bin"` ...
Restore [==================================================] 100% `vl53l5cx/nvm_cmd.bin` - complete (128 of 128 bytes).
Make folder `vl53l5cx/sub2` ...
# Send `mkdir "vl53l5cx/sub2"` ...
Make folder `vl53l5cx/sub_directory` ...
# Send `mkdir "vl53l5cx/sub_directory"` ...
# `vl53l5cx/xtalk.bin` : Size: 896 bytes (= 7 packages)
# Send `xmodem receive "vl53l5cx/xtalk.bin"` ...
Restore [==================================================] 100% `vl53l5cx/xtalk.bin` - complete (896 of 896 bytes).
# `vl53l5cx/sub2/202604251745.opt` : Size: 896 bytes (= 7 packages)
# Send `xmodem receive "vl53l5cx/sub2/202604251745.opt"` ...
Restore [==================================================] 100% `vl53l5cx/sub2/202604251745.opt` - complete (896 of 896 bytes).
Make folder `vl53l5cx/sub2/sub3` ...
# Send `mkdir "vl53l5cx/sub2/sub3"` ...
# `vl53l5cx/sub_directory/202604251745_filetree.txt` : Size: 206 bytes (= 2 packages)
# Send `xmodem receive "vl53l5cx/sub_directory/202604251745_filetree.txt"` ...
Restore [==================================================] 100% `vl53l5cx/sub_directory/202604251745_filetree.txt` - complete (256 of 206 bytes).
# `vl53l5cx/sub_directory/202604251745_options.txt` : Size: 291 bytes (= 2 packages)
# Send `xmodem receive "vl53l5cx/sub_directory/202604251745_options.txt"` ...
Restore [==================================================] 100% `vl53l5cx/sub_directory/202604251745_options.txt` - complete (384 of 291 bytes).
# `vl53l5cx/sub2/sub3/conf.bin` : Size: 1024 bytes (= 8 packages)
# Send `xmodem receive "vl53l5cx/sub2/sub3/conf.bin"` ...
Restore [==================================================] 100% `vl53l5cx/sub2/sub3/conf.bin` - complete (1024 of 1024 bytes).
Restore library from `202604251745.lib` (y/n)? n
Backup `F:\Dropbox\__GIT\picom\miiha_202604251745` successfully restored.
 13 file(s) copied, 4 folder(s) created; 0 failed
 2 backup management files ignored
Trying to launch terminal programm ...
# Launching `C:\Program Files (x86)\teraterm5\ttermpro.exe` ...
# Done.
Check:
(picom) PS F:\Dropbox\__GIT\picom> python picom.py -t -s "COM5" ft
Retrieving file tree from `A:` :
# Sending `files "A:/"` ...
# Sending `files "A:/vl53l5cx/"` ...
# Sending `files "A:/vl53l5cx/sub2/"` ...
# Sending `files "A:/vl53l5cx/sub2/sub3/"` ...
# Sending `files "A:/vl53l5cx/sub_directory/"` ...
Content of `A:` :
├──vl53l5cx
│  ├──sub2
│  │  ├──sub3
│  │  │  └──conf.bin
│  │  └──202604251745.opt
│  ├──sub_directory
│  │  ├──202604251745_filetree.txt
│  │  └──202604251745_options.txt
│  ├──firmware.bin
│  ├──nvm_cmd.bin
│  └──xtalk.bin
├──.fm
├──202604251745.lib
├──bootcount
├──lib_vl53.bas
├──miiha.bas
└──tof.dat
# Done.
Backup:
(picom) PS F:\Dropbox\__GIT\picom> python picom.py -t -s "COM5" -n "miiha" b
# Check drive ...
# Create unique local folder for backup ...
# Get option list ...
# Sending `option list` ...
 Save options to "202604260741.opt" file ...
# Sending `option disk save "202604260741.opt"` ...
 Save library, if exists, to `202604260741.lib` ...
# Sending `library disk save "202604260741.lib"` ...
 Parsing `A:/` ...
15 file(s) and 4 folder(s) found.
Create backup of PicoMite @`COM5` :
 Backup folder : `F:\Dropbox\__GIT\picom\miiha_202604260741`
Create local folder `F:\Dropbox\__GIT\picom\miiha_202604260741\vl53l5cx`
Create local folder `F:\Dropbox\__GIT\picom\miiha_202604260741\vl53l5cx\sub2`
Create local folder `F:\Dropbox\__GIT\picom\miiha_202604260741\vl53l5cx\sub2\sub3`
# Send `xmodem s "vl53l5cx/sub2/sub3/conf.bin"` ...
Backup [==================================================] 100% `vl53l5cx/sub2/sub3/conf.bin` - complete (1024 of 1024 bytes).
# Send `xmodem s "vl53l5cx/sub2/202604251745.opt"` ...
Backup [==================================================] 100% `vl53l5cx/sub2/202604251745.opt` - complete (896 of 896 bytes).
Create local folder `F:\Dropbox\__GIT\picom\miiha_202604260741\vl53l5cx\sub_directory`
# `vl53l5cx/sub_directory/202604251745_filetree.txt` : Size: 256 bytes (= 2 packages)
# Send `xmodem s "vl53l5cx/sub_directory/202604251745_filetree.txt"` ...
Backup [==================================================] 100% `vl53l5cx/sub_directory/202604251745_filetree.txt` - complete (256 of 256 bytes).
# `vl53l5cx/sub_directory/202604251745_options.txt` : Size: 384 bytes (= 3 packages)
# Send `xmodem s "vl53l5cx/sub_directory/202604251745_options.txt"` ...
Backup [==================================================] 100% `vl53l5cx/sub_directory/202604251745_options.txt` - complete (384 of 384 bytes).
# Send `xmodem s "vl53l5cx/firmware.bin"` ...
Backup [==================================================] 100% `vl53l5cx/firmware.bin` - complete (86016 of 86016 bytes).
# Send `xmodem s "vl53l5cx/nvm_cmd.bin"` ...
Backup [==================================================] 100% `vl53l5cx/nvm_cmd.bin` - complete (128 of 128 bytes).
# Send `xmodem s "vl53l5cx/xtalk.bin"` ...
Backup [==================================================] 100% `vl53l5cx/xtalk.bin` - complete (896 of 896 bytes).
# `.fm` : Size: 64 bytes (= 0 packages)
# Send `xmodem s ".fm"` ...
Backup [==================================================] 100% `.fm` - complete (128 of 64 bytes).
# Send `xmodem s "202604251745.lib"` ...
Backup [==================================================] 100% `202604251745.lib` - complete (26368 of 26368 bytes).
# `202604260741.lib` : Size: 26188 bytes (= 205 packages)
# Send `xmodem s "202604260741.lib"` ...
Backup [==================================================] 100% `202604260741.lib` - complete (26240 of 26188 bytes).
# `202604260741.opt` : Size: 896 bytes (= 7 packages)
# Send `xmodem s "202604260741.opt"` ...
Backup [==================================================] 100% `202604260741.opt` - complete (896 of 896 bytes).
# Send `xmodem s "bootcount"` ...
Backup [==================================================] 100% `bootcount` - complete (128 of 128 bytes).
# Send `xmodem s "lib_vl53.bas"` ...
Backup [==================================================] 100% `lib_vl53.bas` - complete (40192 of 40192 bytes).
# Send `xmodem s "miiha.bas"` ...
Backup [==================================================] 100% `miiha.bas` - complete (32896 of 32896 bytes).
# Send `xmodem s "tof.dat"` ...
Backup [==================================================] 100% `tof.dat` - complete (2048 of 2048 bytes).
Backup `miiha_202604260741` successfully created.
 15 file(s) and 4 folder(s) saved; 0 failed
# Done.
toml_12953
Posted: 04:38am 28 Apr 2026
Hi toml_12953,
Best
Thomas
Here's the beginning of my attempt at backup with arguments -d B: -n MyBackup b
 Save options to "202604280028.opt" file ...
 Save library, if exists, to `202604280028.lib` ...
 Parsing `B:/` ...
Warning: Entry #62 (`13:59 09-02-2026       4220  thomas att`) not recognized.
Warning: Entry #63 (`ractor.bas`) not recognized.
Warning: Entry #66 (`s`) not recognized.
Warning: Entry #0 (`B:/benches`) not recognized.
Warning: Entry #0 (`B:/creative`) not recognized.
Warning: Entry #2 (`bas`) not recognized.
Warning: Entry #5 (`bas`) not recognized.
Warning: Entry #7 (`s`) not recognized.
Warning: Entry #13 (`.bas`) not recognized.
Warning: Entry #17 (`bas`) not recognized.
Warning: Entry #19 (`t.bas`) not recognized.
Warning: Entry #21 (`bas`) not recognized.
Warning: Entry #24 (`s`) not recognized.
Warning: Entry #3 (`bas`) not recognized.
Warning: Entry #5 (`as`) not recognized.
Warning: Entry #8 (`as`) not recognized.
Warning: Entry #10 (`as`) not recognized.
Warning: Entry #15 (`s`) not recognized.
Warning: Entry #19 (`as`) not recognized.
Warning: Entry #24 (`e.bas`) not recognized.
09:24 14-10-2024        589  diamond.ba`) not recognized.
Warning: Entry #26 (`s`) not recognized.
Warning: Entry #30 (`as`) not recognized.
Warning: Entry #32 (`as`) not recognized.
Warning: Entry #34 (`as`) not recognized.
Warning: Entry #37 (`bas`) not recognized.
Warning: Entry #39 (`as`) not recognized.
Warning: Entry #41 (`wins.bas`) not recognized.
Warning: Entry #47 (`bas`) not recognized.
Warning: Entry #49 (`s`) not recognized.
09:24 14-10-2024       3441  hello.bas`) not recognized.
Warning: Entry #52 (`as`) not recognized.
Warning: Entry #65 (`.bas`) not recognized.
Warning: Entry #67 (`s`) not recognized.
Warning: Entry #71 (`.bas`) not recognized.
Warning: Entry #73 (`as`) not recognized.
09:24 14-10-2024      15144  mine.bas`) not recognized.
Warning: Entry #76 (`s`) not recognized.
Warning: Entry #79 (`.bas`) not recognized.
Warning: Entry #83 (`as`) not recognized.
Warning: Entry #85 (`09:24 14-10-2024      21206  oregon tra`) not recognized.
Warning: Entry #86 (`il.bak.bas`) not recognized.
Warning: Entry #87 (`09:24 14-10-2024      21216  oregon tra`) not recognized.
Warning: Entry #88 (`il.bas`) not recognized.
Warning: Entry #95 (`s`) not recognized.
Warning: Entry #98 (`rs.bas`) not recognized.
09:24 14-10-2024       6370  roulette.b`) not recognized.
Warning: Entry #100 (`as`) not recognized.
Warning: Entry #102 (`lette.bas`) not recognized.
Warning: Entry #105 (`.bas`) not recognized.
Warning: Entry #107 (`as`) not recognized.
Warning: Entry #113 (`t.bas`) not recognized.
Warning: Entry #116 (`rek.bas`) not recognized.
Warning: Entry #118 (`rekins.bas`) not recognized.
Warning: Entry #120 (`s`) not recognized.
Warning: Entry #123 (`.bas`) not recognized.
09:24 14-10-2024       3135  tictactoe2`) not recognized.
Warning: Entry #125 (`.bas`) not recognized.
Warning: Entry #131 (`s`) not recognized.
Warning: Entry #134 (`Error : Invalid character: "`) not recognized.
Warning: Entry #0 (`B:/nixie`) not recognized.
Warning: Entry #0 (`B:/solutions`) not recognized.
Warning: Entry #2 (`eter.bas`) not recognized.
Warning: Entry #4 (`as`) not recognized.
Warning: Entry #10 (`r.bas`) not recognized.
Warning: Entry #12 (`ci.bas`) not recognized.
Warning: Entry #14 (`ng.bas`) not recognized.
Warning: Entry #16 (`bas`) not recognized.
Warning: Entry #18 (`.bas`) not recognized.
Warning: Entry #20 (`as`) not recognized.
Warning: Entry #22 (`bas`) not recognized.
Warning: Entry #24 (`bas`) not recognized.
Warning: Entry #1 (`tions.bas`) not recognized.
Warning: Entry #3 (`ic.bas`) not recognized.
Warning: Entry #5 (`ic.bas`) not recognized.
Warning: Entry #7 (`.bas`) not recognized.
Warning: Entry #9 (`ic.bas`) not recognized.
Warning: Entry #11 (`nown.bas`) not recognized.
Warning: Entry #13 (`b.bas`) not recognized.
Warning: Entry #15 (`e.bas`) not recognized.
Warning: Entry #17 (`m`) not recognized.
Warning: Entry #19 (`a`) not recognized.
Warning: Entry #22 (`q`) not recognized.
Warning: Entry #24 (`rean`) not recognized.
21:21 14-03-2019       1140  28.coordge`) not recognized.
Warning: Entry #26 (`om`) not recognized.
Warning: Entry #28 (`d-pi`) not recognized.
Warning: Entry #30 (`lar`) not recognized.
Warning: Entry #32 (`oord`) not recognized.
Warning: Entry #35 (`e`) not recognized.
Warning: Entry #37 (`ine`) not recognized.
Warning: Entry #40 (`ile`) not recognized.
Warning: Entry #42 (`ot`) not recognized.
Warning: Entry #48 (`eidel`) not recognized.
11:20 27-04-2025        790  43.self-ge`) not recognized.
Warning: Entry #50 (`nint`) not recognized.
Warning: Entry #54 (`e`) not recognized.
Warning: Entry #56 (`ed`) not recognized.
Warning: Entry #58 (`-div`) not recognized.
Warning: Entry #60 (`den`) not recognized.
Warning: Entry #62 (`mb`) not recognized.
Warning: Entry #64 (`e`) not recognized.
Warning: Entry #66 (`ime`) not recognized.
Warning: Entry #68 (`erse`) not recognized.
Warning: Entry #71 (`erse`) not recognized.
Warning: Entry #73 (`l1`) not recognized.
02:25 06-03-2019        830  55a.perp-c`) not recognized.
Warning: Entry #75 (`al-2`) not recognized.
Warning: Entry #77 (`act`) not recognized.
Warning: Entry #79 (`fact2`) not recognized.
Warning: Entry #83 (`e-gen`) not recognized.
Warning: Entry #85 (`ne`) not recognized.
Warning: Entry #87 (`-pi`) not recognized.
Warning: Entry #90 (`y`) not recognized.
Warning: Entry #92 (`tion`) not recognized.
Warning: Entry #94 (`alysis`) not recognized.
Warning: Entry #96 (`-roots`) not recognized.
Warning: Entry #98 (`ea`) not recognized.
15:40 30-07-2015        402  69.trapezo`) not recognized.
Warning: Entry #100 (`idal`) not recognized.
Warning: Entry #102 (`ns`) not recognized.
Warning: Entry #104 (`-fahr`) not recognized.
Warning: Entry #106 (`ss-vs-speed`) not recognized.
Warning: Entry #110 (`t`) not recognized.
Warning: Entry #112 (`sort`) not recognized.
Warning: Entry #114 (`oe`) not recognized.
Warning: Entry #115 (`14:43 15-03-2025        255  8-Bit Benc`) not recognized.
Warning: Entry #116 (`hmark`) not recognized.
Warning: Entry #118 (`ome`) not recognized.
Warning: Entry #9 (`28.lib`) not recognized.
Warning: Entry #11 (`28.opt`) not recognized.
Warning: Entry #13 (`bas`) not recognized.
Warning: Entry #19 (`mp3`) not recognized.
Warning: Entry #20 (`07:42 12-03-2026        261  balloon te`) not recognized.
Warning: Entry #21 (`st.bas`) not recognized.
Warning: Entry #23 (`r`) not recognized.
241 file(s) and 7 folder(s) found.
Create backup of PicoMite @`COM21` :
 Backup folder : `E:\Users\tlake\Documents\ClockworkPi\PicoCalc\picom-main\MyBackup_202604280028`
Create local folder `E:\Users\tlake\Documents\ClockworkPi\PicoCalc\picom-main\MyBackup_202604280028\basicprogs`
Error: File `basicprogs/BellLabs_F` not found ... skipped.
Error: File `basicprogs/bezier.bas` not found ... skipped.
Error: File `basicprogs/bifdiag.ba` not found ... skipped.
Error: File `basicprogs/bytesieve.` not found ... skipped.
Error: File `basicprogs/Chessnovic` not found ... skipped.
Error: File `basicprogs/Comp.bas` not found ... skipped.
Error: File `basicprogs/frametst.b` not found ... skipped.
Error: File `basicprogs/galaxian.b` not found ... skipped.
Error: File `basicprogs/hat.BAS` not found ... skipped.
Error: File `basicprogs/julia.bas` not found ... skipped.
Error: File `basicprogs/keydisp.ba` not found ... skipped.
Error: File `basicprogs/lcdnixie.b` not found ... skipped.
Error: File `basicprogs/Lemm13x20.` not found ... skipped.
Error: File `basicprogs/lorenz.bas` not found ... skipped.
Error: File `basicprogs/mand.bas` not found ... skipped.
Error: File `basicprogs/Mandelbrot` not found ... skipped.
Backup [==================================================] 100% `basicprogs/menu.bas` - complete (1408 of 1356 bytes).
Footnote added 2026-04-28 15:14 by toml_12953
NB: One error is that menu.bas is NOT in the basicprogs subdirectory.
toml_12953
Posted: 04:47am 28 Apr 2026
Hi toml_12953,
Best
Thomas
I just tried it again and now I get this:
Traceback (most recent call last):
 File "E:\Users\tlake\Documents\ClockworkPi\PicoCalc\picom-main\picom.py", line 1328, in <module>
   picoID = isPicoMitePresent()
 File "E:\Users\tlake\Documents\ClockworkPi\PicoCalc\picom-main\picom.py", line 350, in isPicoMitePresent
   return res[0] if len(res[0]) > 0 else ""
IndexError: list index out of range
The screen on the PicoCalc shows
>?MM.INFO(ID)
2CFC52F9A68
Edited 2026-04-28 14:49 by toml_12953
karlelch
Posted: 09:24pm 28 Apr 2026
Thanks toml_12953
Looks like a timing issue. Will look into that on the weekend.
Best
Thomas
