Local Time 18:41 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Another question about ASTRO
PhilP
Posted: 08:19am 13 May 2026
Good morning. I have been following at a distance Peter's extremely clever astronomy developments. I have been trying to calculate sunrise and sunset times using various algorithms from NASA and TassyJim's previous programmes but none seem to give a sensible result. There was a simple version of the FotS but it isn't there any more.
I am assuming that the maths needed to do the sunrise/sunset calculations are in some form behind the scenes in the ASTRO function. My question is could ASTRO be used to calculate sunrise and sunset times? From my reading of the function I think I would have to do iterative calculations testing date and time at a LOCATION and look for a sun elevation of zero.
Thanks for any feedback
Phil
Posted: 09:26am 13 May 2026
Do you know what it was called on FotS?  It may be on archive.org or someone may have a copy.
BarryH
Posted: 10:18am 13 May 2026
Quick & Dirty Daylight Indicator, perhaps
https://fruitoftheshed.com/wiki/doku.php?id=mmbasic:quick_and_dirty_daylight_indicator
BarryH
Posted: 10:41am 13 May 2026
You can use the astro command to do this by iterating when the sun is at 5 degrees below the horizon
Posted: 01:37pm 13 May 2026
I use this Annex Basic code. If it would give you a suitable answer, you should be able to modify it for MMBasic. I asked for the "civil_twilight" value.
dawndusk:
 aa1$="https://api.sunrise-sunset.org/json?"
 aa2$="lat=44.0&lng=-64.7&tzid=America/Halifax"
 aa$=wget$(aa1$+aa2$)
 dawn$="06:50:00" ' AM
 dusk$="17:37:00" ' PM
 if instr(aa$,"No Data") = 0 then
   dawn$=json$(aa$,"results.civil_twilight_begin")
   wlog "dawn: "+dawn$
   dusk$=json$(aa$,"results.civil_twilight_end")
   dusk$=str$(val(mid$(dusk$,1,1))+12)+mid$(dusk$,2) ' 12-hour clock
   wlog "dusk: "+json$(aa$,"results.civil_twilight_end")
 endif
 return
(wlog is print to a console)
PhilP
Posted: 03:09pm 13 May 2026
Thanks everyone.
@JohnS - I thought it had sunset in its title and there doesn't appear to be  a title like that on FotS. However the file @BarryH pointed me at at was probably what i remembered.
@Peter - I want to try the ASTRO method but I have now found the old program I remember  from the Forum - attached.  I have adapted it to my location and the result is within a minute of the official sunset/sunrise times. I plan to run it on a MX170 but it is needed only once a day.
@lizby - thanks for the Annex code - I use them extensively for applications IoT projects monitoring parameters to upload to Thingspeak for example. I wanted the MX170 to be independent of the internet so the calculation method was the solution.
Phil
sunset_rise back shed original.zip
barewires
Posted: 03:11am 16 May 2026
I have been using the free BASIC programs from Sky and Telescope since the mid 80s.
https://skyandtelescope.org/astronomy-resources/basic-programs-from-sky-telescope/
BarryH
Posted: 07:27am 16 May 2026
@barewires - looks to be a good resource / rabbit hole to translate a few utilities to MMBasic
BarryH
zeitfest
Posted: 01:39am 17 May 2026
Have a look at this which is similar
Edited 2026-05-17 11:41 by zeitfest
