Local Time 18:41 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Basic Program for comparing variable stars using two comparison stars
RicM
Posted: 03:01am 20 May 2026
Dear Members
Proabably asked this before but has anyone done a program for the RP2350B V6 basic i hope number is correct.
RicM
LeoNicolas
Posted: 03:25am 20 May 2026
Hi Ric
Can you explain better what you need?
Maybe some examples will help me to understand what exactly you want
toml_12953
Posted: 04:18am 20 May 2026
  RicM said  Dear Members
RicM
Here's my attempt:
Added VARSTAR.bas — a BASIC program for variable-star magnitude using the standard two-comparison-star method (AAVSO / Henden style).
What it does
You enter:
1. Catalog magnitudes of comparison stars 1 and 2 (M1, M2)
2. Measured brightness (counts, flux, ADU, etc.) for comp1, comp2, and the variable (B1, B2, V1)
When your comps match the catalog (D2 ≈ D1), the correction term is small. Instrumental magnitudes use log₁₀ via LOG(x)*K with K = 1/LOG(10).
Example
Input       Value
M1, M2        10.5, 11.0
B1, B2, V1   1000, 800, 950
→ V ≈ 10.024
The program rejects non-positive brightness and warns if the two comps are too close in measurement (D2 ≈ 0), which would make the correction unreliable.
Program:
05 REM--VARIABLE STAR MAGNITUDE FROM TWO COMP STARS
10 REM--AAVSO / HENDEN TWO-COMPARISON METHOD
15 REM--V = M1 + D3 - (M1-M2)*(D2-D1)/D2
20 REM--D2, D3 USE LOG10 VIA LOG()*K, K=1/LOG(10)
30 PRINT "VARIABLE STAR PHOTOMETRY"
40 PRINT "TWO COMPARISON STARS"
50 PRINT
60 PRINT "CATALOG MAGNITUDES OF COMP STARS"
70 INPUT M1,M2
80 PRINT "MEASURED BRIGHTNESS (COUNTS/FLUX)"
90 PRINT "COMP1, COMP2, VARIABLE"
100 INPUT B1,B2,V1
110 IF B1<=0 OR B2<=0 OR V1<=0 THEN 500
120 K=1/LOG(10)
130 D1=M1-M2
140 D2=-2.5*LOG(B1/B2)*K
150 D3=-2.5*LOG(V1/B1)*K
160 IF ABS(D2)<1E-12 THEN 510
170 V=M1+D3-(M1-M2)*(D2-D1)/D2
180 PRINT
190 PRINT "INSTR. DIFF C1-C2 (D2)=";D2
200 PRINT "KNOWN DIFF       (D1)=";D1
210 PRINT "INSTR. DIFF VAR-C1 (D3)=";D3
220 PRINT
230 PRINT "VARIABLE MAGNITUDE V =";V
240 END
500 PRINT "BRIGHTNESS MUST BE POSITIVE"
510 PRINT "COMP STARS TOO CLOSE - CHECK DATA"
520 END
Edited 2026-05-27 03:27 by toml_12953
