Local Time 17:09 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help with Picomite INKEY$ Function
apalert
Posted: 01:06pm 11 Jun 2026
Looking to wait for Up or Down arrow to be pressed. Just to test the idea I've been inputting this and similar at the command prompt but doesn't work as hoped!
x=1 : do : loop while inkey$="" : if inkey$ = chr$(128) then x = x+1  : Print x
Posted: 01:17pm 11 Jun 2026
inkey$ consumes the keypress so you can't read it again
x=1
s$=Inkey$
Loop While s$=""
If s$=Chr$(128) Then x=x+1:Print x
Posted: 01:22pm 11 Jun 2026
To make it work on one line:-
> x=1 : do : loop until inkey$ = chr$(128) : inc x : Print x
2
apalert
Posted: 08:52pm 11 Jun 2026
Thanks Peter as always!
Thanks Phil, you've woken me up to using the INC function as well! I figured you can get a decrement using INC variable, -1. Oh boy, when I think of the copious variable = variable + 1 and variable = variable - 1 in my code. Not only does INC look slick, the manual says it processes much faster.
I actually want bigger steps than 1 so I've ended up, as a demo for using both Up and Down keys, with:
dim float x
dim string s$
x=10
do
 s$=Inkey$
 Loop While s$=""
If s$=Chr$(128) Then inc x,10:Print x
If s$=Chr$(129) Then inc x,-10:Print x
loop
PhenixRising
Posted: 07:59am 15 Jun 2026
  apalert said   Not only does INC look slick, the manual says it processes much faster.
Please verify this. It definitely was true but when I tested with Tracecache, the old method was faster.
Posted: 08:39am 15 Jun 2026
> Clear :dim integer n, m
> t=timer:for m=0 to 999999: inc n :next:? timer-t,n,m
3148.165        1000000         1000000
> t=timer:for m=0 to 999999: n=n+1 :next:? timer-t,n,m
5609.588        1000000         1000000
> option list
PicoMiteVGA MMBasic RP2350A Edition V6.03.00RC15
OPTION RESOLUTION 800x600 @ 360000KHz
For comparison the same loop doing nothing.
> t=timer:for m=0 to 999999:       :next:? timer-t,n,m
1227.124        0       1000000
Edited 2026-06-15 18:50 by phil99
toml_12953
Posted: 11:03am 15 Jun 2026
In the following program, replacing statements in the DO LOOP with INC
shaved a few tenths of a second off the time thereby raising the Index:
TIMER =0
CONST loops%=9865
DIM float x, r0
DIM integer i
FOR i=1 TO loops
 r0=10
 DO
   x=r0
   INC x
   INC x,-4.567e-4
   INC x,70
   INC x,-69
   x=x*7
   x=x/11
   INC r0,-1
 LOOP WHILE r0>0
 x=LOG(x)
 x=SIN(x)
 x=SQR(x)
 x=SQR(x)
NEXT i
PRINT x
t=TIMER/1000
PRINT "Loops:";loops
PRINT "Time:";t;" seconds"
PRINT "Index:";34/t*loops
