Local Time 09:15 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic Anywhere ESP32-S3 and ESP32 (CYD) Port
jvanderberg
Posted: 12:52pm 16 Jun 2026
A short demo: https://www.youtube.com/watch?v=zf4n1SS0AKc
I’ve spent the last month porting MMBasic to the ESP32-S3 and ESP32 classic. Both target the ESP-IDF. Because the IDF brings along its own framework and an RTOS, without PSRAM things get a bit tight. Most ESP32-S3s have PSRAM though, and it works well.
I’ve tested on the Freenove 2.8” LCD Capacitive touch (this is like a fancy CYD) and the Adafruit ESP32-S3 Metro. I can recommend the Freenove over just about any CYD, it’s about the same price, has much better sound, PSRAM, and better touch. The Adafruit Metro is a good general purpose dev board, but you’ll have to BYO display and sound.
Both ports support VGA out, though on the ESP32 classic bit depth is pretty limited because of memory constraints.
You can download these in the latest releases:
https://github.com/jvanderberg/PicoMiteAllVersions/releases/tag/latest
MMBasic-Anywhere-esp32-cyd-merged.bin
MMBasic-Anywhere-esp32-s3-octal-merged.bin
MMBasic-Anywhere-esp32-s3-quad-merged.bin
The octal/quad bifurcation is unfortunate. If you don’t get PSRAM working using the ‘octal’, try the ‘quad’.  Sadly this can’t be a runtime option, so I have to publish two images.
PhenixRising
Posted: 03:03pm 16 Jun 2026
Darn it...ANOTHER distraction
I just happen to have the 7" CYD (ESP32-8048S070)
PhenixRising
Posted: 05:03pm 16 Jun 2026
Tried both S3 versions which loaded and verified and then connected via terminal but:
  Quote  invalid header: 0xffffffff
Do you have a particular loading procedure?
jvanderberg
Posted: 06:11pm 16 Jun 2026
  PhenixRising said  Tried both S3 versions which loaded and verified and then connected via terminal but:
Need a bit more detail. What were you trying to do? The readmes in the port directories for each have detailed flashing instructions.
PhenixRising
Posted: 07:00pm 16 Jun 2026
Been looking all afternoon for readmes....Really shouldn't be this hard. WTF!
jvanderberg
Posted: 07:10pm 16 Jun 2026
  PhenixRising said  Been looking all afternoon for readmes....Really shouldn't be this hard. WTF!
https://github.com/jvanderberg/PicoMiteAllVersions/tree/main/ports/esp32_cyd
https://github.com/jvanderberg/PicoMiteAllVersions/tree/main/ports/esp32_s3
Posted: 07:13pm 16 Jun 2026
I expect they're in the ports directories
I don't know which you want but for example there's the esp32_s3
edit: both posting, great minds LOL
Edited 2026-06-17 05:16 by JohnS
PeteCotton
Posted: 08:24pm 16 Jun 2026
Wow! Very cool
Hawk
Posted: 07:52am 22 Jun 2026
Wow, this is really cool.
I have loaded the EPS32 CYD build onto my FabGL board and have it outputing to a VGA screen.
OPTION VGA 22, 21, 19, 18, 5, 4, 23, 15
But I can only operate in Mode 3 because it doesn't have enough memory.
I need to know how to disable the WIFI.
I have tried;
OPTION WIFI
mm_options: loaded options from raw mmslots sector
Error : Syntax
I also need to know how to map the pins for the PS/2 keyboard.
I have tried;
OPTION KEYBOARD PINS 33, 32
Error : Option not supported on this port
I've also tried configuring the SPI bus to connect an SD card but I get the following error;
OPTION SYSTEM SPI 14, 13, 2 and OPTION SYSTEM SPI 14, 12, 2
Both commands give the following result.
Error : Invalid pin
Are you able to help me with this?  I don't need WIFI, but it would be great to have Mode 1 and Mode 2
Thanks,
Mike
Edited 2026-06-22 18:14 by Hawk
dddns
Posted: 08:12am 22 Jun 2026
Try OPTION WIFI "",""
Hawk
Posted: 08:19am 22 Jun 2026
Thanks for the suggestion.
option wifi "",""
Output in serial terminal:
mm_options: saved options to raw mmslots sector
phy_init: failed to load RF calibration data (0x1102), falling back to full calibration
jvanderberg
Posted: 12:02pm 22 Jun 2026
The option wifi “”,””
Should turn off WiFi. CYDs are very memory constrained. I have not tested with a fabgl board.  i haven’t tested ps/2 keyboard at all for these builds and my experience is that if I haven’t tested it it’s likely broken. Do you have a recommend fabgl board I could test with? It would be nice to create a profile for it.
Hawk
Posted: 12:58pm 22 Jun 2026
These are the cheapest ones around.
LilyGo FabGL Board
If you're just after the pin assignments, you can check here.
https://github.com/fdivitto/FabGL/blob/master/fabgl%20GPIOs%20assignment.txt
jvanderberg
Posted: 01:55pm 22 Jun 2026
Btw. Does your fabgl board have psram? I make the assumption these board don’t but it looks like some do.
jvanderberg
Posted: 01:53am 23 Jun 2026
I've ordered a FabGL (or two), seems these are popular enough that a dedicated configuration is called for, it will also give me a test for the PS/2 drivers, and a different VGA configuration.
Hawk
Posted: 03:08pm 23 Jun 2026
  jvanderberg said  Btw. Does your fabgl board have psram? I make the assumption these board don’t but it looks like some do.
From what I can see online, it has 4 or 8 MB PSRAM...I think.
Edited 2026-06-24 01:10 by Hawk
al18
Posted: 07:11pm 23 Jun 2026
The LilyGo FABGL board has 4 MB QSPI Flash according to https://lilygo.cc/products/fabgl-vga32
On the FABGL GitHub page, there’s an 8088 IBM PC emulator and you can run Windows 3.0 on it.
Hawk
Posted: 12:08pm 24 Jul 2026
  jvanderberg said  I've ordered a FabGL (or two), seems these are popular enough that a dedicated configuration is called for, it will also give me a test for the PS/2 drivers, and a different VGA configuration.
Any progress on the FabGL compatibility?
Cheers.
jvanderberg
Posted: 12:27pm 24 Jul 2026
Yes it’s mostly done but the memory management, even with psram is a real pain. And I need to test the other esp32 targets to make sure I didn’t break them. Thanks for checking in.
Hawk
Posted: 01:14pm 24 Jul 2026
Thanks for the update.  Thanks for your effort in getting it working.  I'm looking forward to giving it a try.
