Local Time 14:43 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Unable to connect to geoffg.net or FotS
Posted: 08:18am 13 Jul 2026
My ISP says it's not a problem with my connection or at their end. :(
Posted: 08:45am 13 Jul 2026
I have both at present, though last night the internet dropped out completely here.
The modem LEDs indicated indicated DSL and internet were still on but could not access any sites. Something odd going on...
Posted: 09:03am 13 Jul 2026
Is it Astra, do you think?
Posted: 07:48pm 13 Jul 2026
It won't ping - all packets lost.
A tracert gets as far as Sydney and gets lost shortly after.
circuit
Posted: 08:46pm 13 Jul 2026
I am in the UK and have a full connection, no problem.
al18
Posted: 08:47pm 13 Jul 2026
Works fine from the US
Posted: 12:01am 14 Jul 2026
No issues from Kiwi-land.
Posted: 07:29am 14 Jul 2026
Weird...
I've changed my DNS from the defaults over DHCP to the Google ones. Still nothing.
My ISP can't reach the site either, so that bypasses everything at my end anyway.
I've tried http: rather than https: - still nothing (but I expected that).
@circuit
Would you mind letting me know which ISP you are using? I'll try raising another ticket with that info and the outputs from ping and tracert. They may still do nothing though as the route breaks on the other side of the world!
Posted: 07:32am 14 Jul 2026
Everything is fine at my end.
Posted: 07:47am 14 Jul 2026
Thanks Geoff. I figured it must be as others can connect,
I'm not sure I trust my ISP...
circuit
Posted: 10:03am 14 Jul 2026
  Mixtel90 said  Weird...
@circuit
BT is my provider.
Posted: 11:07am 14 Jul 2026
Thanks. I'll raise another ticket.
LeoNicolas
Posted: 11:08am 14 Jul 2026
Have you tried to use a VPN?
Maybe it will bypass the routing problem
Posted: 11:24am 14 Jul 2026
I'm in the UK and these are OK:
https://geoffg.net/
https://fruitoftheshed.com/wiki/doku.php?id=start
Posted: 12:04pm 14 Jul 2026
Nope. Both are just timing out from here.
Martin H.
Posted: 12:19pm 14 Jul 2026
Germany ok,
  JohnS said  I'm in the UK and these are OK:
https://geoffg.net/
It looks as though it’s down to the DNS provider.
It works for me, although I use DNS addresses
86.54.11.13
86.54.11.1
(within Pihole)
They belong to the public DNS service DNS4EU, an initiative funded by the European Union to improve data protection and security. This resolver is operated and managed by the DNS4EU consortium of the same name.
it seems to work even if you connect from outside the EU
OPTION                                          IPv4 ADDRESS
Protective                                      86.54.11.1
Protective + Child Protection                   86.54.11.12
Protective + Ad Blocking                        86.54.11.13
Protective + Child Protection + Ad Blocking     86.54.11.11
Unfiltered                                      86.54.11.100
 Martin
Edited 2026-07-14 22:44 by Martin H.
'no comment
Posted: 01:56pm 14 Jul 2026
Thanks Martin. :) As a matter of interest I'd been wondering if there was a public DNS based in the EU that I could use.
Still doesn't work for me though.  :(
I opened another ticket and I'm currently waiting for a reply.
Update:
They've escalated it to their technical team.  :)
Edited 2026-07-15 01:03 by Mixtel90
PhenixRising
Posted: 08:27am 15 Jul 2026
Works perfectly in Blackburn, bud.
When I want to access Bitchute that was blocked by Starmer, I simply use the Tor browser which makes it look like I'm in Switzerland. No cost.
Posted: 08:49am 15 Jul 2026
My ISP (YouFibre) is a relatively new (2019) startup FTTP company. So far I've been pretty impressed, but it looks like they have a routing problem somewhere at the moment. They pair with Netomnia for the hardware network so you can't just assume that because an Openreach-carried ISP works this one will.
We'll see what their tech people come up with. It's hardly the end of the world. :)
LeoNicolas
Posted: 10:34am 15 Jul 2026
You can try to use Firefox or Opera and activate their free VPN. Maybe this will help
