Local Time 13:53 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic: soliciting syntax suggestions for fun/cmd to read image size
Posted: 12:12am 28 Jul 2026
Hi folks,
I find myself wanting to add support to MMB4L to get the width and height of an image file - png in particular.
I have two ideas for syntax, either a function:
size% = MM.INFO(IMAGE SIZE filename$)
Which returns width and height in the lower and upper words respectively of the 64-bit size% variable.
Or a command:
IMAGE GETSIZE filename$, width%, height%
Where width% and height% are filled on return (act as pass by reference variables) - I have used the same pattern previously due the CONSOLE GETSIZE command.
In both cases I was proposing to determine the image type from the file extension.
Any suggestions?
EDNEDN
Posted: 02:52am 28 Jul 2026
MM.Info() would be a more natural and consistent fit in my opinion.
