Local Time 12:22 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Windows Update
palcal
Posted: 09:31pm 23 Aug 2026
My daughter has a laptop that was upgraded to Win 11 from Win 10. For over a year it has been trying to install the 25H2 update without success, it gets to 62% and fails.
I've tried looking up the error number ox8007001f with no luck. It has 238Gb of free space. I even reinstalled Win 11. I did eeverything I could to disable windows update withou success.
greybeard
Posted: 12:34am 24 Aug 2026
I googled the error number '0x8007001f windows 11' and there was a lot of hits, mainly 'device attached not functioning correctly' which tends to point to a driver error or a corrupted system files or broken user profile.
All had further info on possible solutions.
Good luck
palcal
Posted: 01:56am 24 Aug 2026
I Googled it as well, I tried everything I could. I would be happy just to turn updates off but I've been unable to do that. I'll try doing it in the registry again and see how I go.
palcal
Posted: 02:01am 24 Aug 2026
I just disabled update in Services.msc it was set to manual, I did this before but not correctly apparently, I'll see what happens now.
Posted: 03:10am 24 Aug 2026
so is the computer continually re-downloading the update after each fail? if so, and many other machines are doing likewise, i wonder how much impact this sort of issue (collectively) has on internet traffic worldwide.
rob   :-)
Edited 2026-08-24 14:09 by robert.rozee
palcal
Posted: 05:51am 24 Aug 2026
Yes, probably a lot. Maybe it just checks to see if has already been downloaded. I don't know where it resides after download so I can't check how many downloads are there. I have now disabled update so I'll see what happens.
PhenixRising
Posted: 10:00am 24 Aug 2026
I had something similar; every time I rebooted, Windows would try to update. I would wait an eternity and then it announced that the update failed and was reverting back. I searched this and the solution was to remove the update that was trying to install but I have forgotten what steps I took. IIRC, the update came again, at a later date and installed successfully.
Bryan1
Posted: 12:33pm 24 Aug 2026
yea the laptop I'm using said I had updates and it said it was security patch's then I found a don't switch off as a new win11 is being installed so no choice to back out. Thankful;ly it it go smooth and had no problems but I am touching wood as we speak
