58kk90 Regular Member Joined: 14/06/2023 Location: United KingdomPosts: 82
Posted: 07:30am 15 Oct 2026
Morning,
I have just tried the new 7.0.00b8 version on an RP2040 Mini with one of the 1.3" I2C Oled displays attached.
I used the file 'PicoMiteRP2040MINV7.0.00b8.uf2' from github. When I enter
OPTION SYSTEM I2C GP12, GP13
the line is accepted and the RP2040 mini reboots, but when I then enter
OPTION LCDPANEL SSD1306I2C, LANDSCAPE , 2
I get the error message
'Error : SSD1963 displays not enabled'
If I write the file for the standard RP2040 pico 'PicoMiteRP2040V7.0.00b8.uf2' to the RP2040 mini, then both commands are fine and the oled works too.
I also tried using version 'PicoMiteRP2040MINV6.03.00.uf2' and I get the same error message that I get with the v7 version about SSD1963 display not enabled.
Can anyone confirm please the RP2040 mini does support the SSD1306I2C display?
Tony
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12007
Posted: 07:49am 15 Oct 2026
bug - will fix
