Forum Index : Microcontroller and PC projects : Pico 3 microcomputer
| RicM Regular Member Joined: 05/02/2022 Location: AustraliaPosts: 60 |
Dear Matherp, I am very interested in the Pico 3 and the adapter using the gpio port for a VGA adapter. When will these be available. KInd Regards, RicM |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9206 |
Your best bet is probably to contact Grogster, who posts on here. He might be able to sort you out with a one-off from New Zealand. matherp doesn't supply boards, kits etc. Mick Zilog Inside! nascom.info for Nascom & Gemini |
