Forum Index : Microcontroller and PC projects : Cheap touchscreen monitor with both hdmi and vga
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12083 |
Found this , currently a great price in the UK, Tested on PC3 and also VGAUSBRP2350 code |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9260 |
Ordered. :) Thanks, I was looking for something like that. Mick Zilog Inside! nascom.info for Nascom & Gemini |
| homa Guru Joined: 05/11/2021 Location: GermanyPosts: 734 |
What about the price? I can't see that from Germany. |
| Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1574 |
£66.39 (via VPN) bei Ebay.de EUR 89,67 (used) Edited 2026-10-27 22:14 by Martin H. 'no comment |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1783 |
https://www.amazon.de/Kenowa-Touchscreen-Sichtschutz-Lautsprecher-Bildschirm/dp/B0DC5Z32X8/ref=sr_1_7? 109 € - 15 € Coupon Edited 2026-10-27 22:24 by twofingers |
thx @all |
| Wölfi Newbie Joined: 14/10/2026 Location: GermanyPosts: 29 |
How does it actually work. Does it completely replace a mouse (on the Picomite)? I never had such a device at all. How is it connected? |
Plugs into a usb host port on the Picomite (and soon the CMM2) and then can be read with the touch function. It can also be used for GUI controla and there is an on screen keyboard available ' tt.bas - USB touch screen test: touch the screen; the program stops after 5 minutes or Ctrl-C. The screen shows the ' touch on three fixed lines and a dot under each finger; PRINT goes to the serial console only (the log). Option Explicit Dim integer s, p, r, d, was, x, y, n, lastn Dim g$, last$ Dim float t0 = Timer Option Console Serial CLS Do While Timer - t0 < 295000 d = Touch(Down) : x = Touch(X) : y = Touch(Y) : n = Touch(XN 0) Text 0, 0, "X " + Str$(x, 5) + " Y " + Str$(y, 5) + " DOWN " + Str$(d) + " contacts " + Str$(n) + " ", "LT" If n >= 2 Then Text 0, 14, "2nd contact X " + Str$(Touch(X2), 5) + " Y " + Str$(Touch(Y2), 5) + " ", "LT" Else Text 0, 14, Space$(40), "LT" EndIf If d Then Circle x, y, 3, , , RGB(yellow), RGB(yellow) If n >= 2 Then Circle Touch(X2), Touch(Y2), 3, , , RGB(cyan), RGB(cyan) If d And Not was Then Print "down"; x; y; " contacts"; n If was And Not d Then Print "up" If n <> lastn And n >= 2 Then Print " contacts"; n; " 2nd at"; Touch(X2); Touch(Y2) lastn = n : was = d g$ = "" s = Touch(Swipe) : If s Then g$ = g$ + "swipe " + Choice(s = 1, "left ", Choice(s = 2, "right ", Choice(s = 3, "up ", "down "))) If Touch(Tap) Then g$ = g$ + "tap " If Touch(DTap) Then g$ = g$ + "double-tap " If Touch(Hold) Then g$ = g$ + "hold " p = Touch(Pinch) : If p Then g$ = g$ + Choice(p = 1, "expand ", "contract ") r = Touch(Rotate) : If r Then g$ = g$ + Choice(r = 1, "clockwise ", "anticlockwise ") If Touch(TTap) Then g$ = g$ + "two-finger-tap " If g$ <> "" Then last$ = g$ : Print "gesture: "; g$ Text 0, 28, Left$("last gesture: " + last$ + Space$(50), 60), "LT" Pause 10 Loop Option Console Both Print "done" |
| PhenixRising Guru Joined: 07/11/2023 Location: United KingdomPosts: 2110 |
Fandabidozi |
Thanks for showing! Something to keep in mind for the next steps down the line. |
