Local Time 21:40 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bench marks for fun...
hhtg1968
Posted: 09:45pm 31 Oct 2026
3 videos from cmm2 and pico computer (mmbasic7)
1.
both computer are calculating kind of cellular automaton. algorithm in basic, many if and thens per pixel. picomite ist twice as fast. source code is the same.
video at youtube:
pico is left - cmm2 is right
2. changed demo from matherp for the ray command:
resolution 640x480
same source
cmm2 not in picomite mode
cmm2 is fast and smooth
picomite is slower
video picomite:
ray - picomite
video cmm2:
ray - cmm2
Posted: 08:22am 01 Nov 2026
I think this is sort of what I expected. I'm not sure about test 1, but in test 2 the CMM2 has dedicated high speed RAM for the video. The PicoMite has to make do with ordinary RAM which, although on-chip, isn't particularly high speed.
I assume that the Pico is a PC3 using HDMI? That may also introduce an overhead over using VGA, I don't know.
The two systems are very different in terms of hardware, even if they are both running similar MMBasic.
Just for giggles, try the Pico with the compiler on if you can. :)
Posted: 09:33am 01 Nov 2026
Please post the cellular automation code so I can use it to test. I suspect the difference is that one of the commands is waiting for frame blanking in the CMM2 and not in the Picomite
