Local Time 06:28 10 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Stumped with GUi Controls
OA47
Posted: 04:38am 07 Nov 2026
MM.VER=6.0201 on Pi Pico 2 W, when I try to define any one of 4 Buttons I require using GUI BUTTON #1, "EXIT", 0, 280, 90, 30, RGB(RED)  I get GUI reference number #NN is in use. I have defined 80 in memory but it seems whatever number I try I get the ERROR.
Help needed please
OA47
mozzie
Posted: 06:50am 07 Nov 2026
G'day OA47,
Can you let us know which flavour of V6.02.01 you are using?
You mention a Pico2W, are you using the WebMite firmware?
Regards, Lyle.
Edited 2026-11-07 16:51 by mozzie
OA47
Posted: 07:25am 07 Nov 2026
Lyle thankyou for your help. MM.Device$=WebMiteRP2350A
OA47
mozzie
Posted: 07:41am 07 Nov 2026
OA47,
No worries, can you also let us know your option list, just in case it is display specific?
Just tried:
> list
'prog to test gui controls
Option default integer
GUI button #1,"1",10,10,100,20,RGB(red)
GUI button #2,"2",10,30,100,20,RGB(green)
GUI button #3,"3",10,50,100,20,RGB(yellow)
GUI button #4,"4",10,70,100,20,RGB(blue)
End
And it ran ok but I don't have a physical display connected so cannot see the output.
> option list
WebMite MMBasic RP2350A Edition V6.02.01
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION CPUSPEED (KHz) 200000
OPTION LCDPANEL ILI9488, RLANDSCAPE,GP14,GP13,GP12,GP20
OPTION GUI CONTROLS 32
Also tried option lcdpanel virtual_C but that is causing other problems:
> edit
PC=>
Might also be worth updating to a later firmware, is there a reason for sticking with V6.02.01?
Regards, Lyle.
Posted: 07:49am 07 Nov 2026
As you have OPTION LCDPANEL ILI9488 try OPTION LCDPANEL DISABLE then:
You can then save the image.
I don't have a Pico 2 W but "GUI button #1,"1",10,10,100,20,RGB(red)" works with the virtual LCD on the non-W versions.
mozzie
Posted: 07:59am 07 Nov 2026
G'day Phil99,
oops, should have grabbed the whole command string:
> option lcdpanel disable
> edit
PC=> print mm.ver
6.0201
Regards, Lyle.
OA47
Posted: 08:23pm 07 Nov 2026
Here is the OPTION LIST
> option list
OPTION SYSTEM I2C GP26,GP27
OPTION AUTORUN  ON
OPTION LCDPANEL ILI9488, RLANDSCAPE,GP15,GP14,GP13,GP17
OPTION GUI CONTROLS 80
OPTION WIFI ************, **********, PICO02C1AC7E09D
OPTION TOUCH GP12,GP11
GUI CALIBRATE 0, 169, 166, 1282, 885
OPTION SDCARD GP22
OPTION AUDIO GP2,GP3', ON PWM CHANNEL 1
mozzie
Posted: 12:14am 08 Nov 2026
G'day OA47,
Found a Silicon Chip Pico Backpack with almost the same option list, now with Pico2W fitted.
> option list
OPTION TOUCH GP15,GP17
GUI CALIBRATE 0, 210, 156, 1284, 845
OPTION SDCARD GP21
And this short program to test gui buttons:
> list
GUI button #1,"ONE",10,10,100,20,RGB(red),RGB(green)
GUI button #2,"TWO",10,30,100,20,RGB(green),RGB(red)
GUI button #3,"THREE",10,50,100,20,RGB(yellow),RGB(blue)
GUI button #4,"FOUR",10,70,100,20,RGB(blue),RGB(yellow)
 For i = 1 To 4
   CtrlVal(i)=1
   Pause 1000
   CtrlVal(i)=0
 Next
Loop While Inkey$=""
End
And all working ok. A couple of suggestions:
Try OPTION AUTORUN OFF and without the WIFI network
Reload the firmware with a CLEAR FLASH RP2350 or CLEAR FLASH UNIVERSAL first.
Is it possible there is a different GUI CONTROL with the same #reference number? they all have to be unique.
Hopefully something works.
Regards, Lyle.
OA47
Posted: 12:17am 08 Nov 2026
Lyle, I have stripped out all other GUI references and turned off the WIFI but still no go. I will reflash the Pico, reload and test again.
OA47
I have cleared the Pico and loaded 6.03 but I still have the same error. Can someone please point me to CLEAR FLASH RP2350 file?
Edited 2026-11-08 10:54 by OA47
mozzie
Posted: 02:30am 08 Nov 2026
OA47,
All 3 versions in ZIP file below, sometimes CLEAR_FLASH_RP2350 works and sometimes CLEAR_FLASH_UNIVERSAL, it may depend on the version of the Pico.
Clear_Flash_ALL.zip
The fact V6.03.?? is giving problems is very strange, however the problem with LCDPANEL VIRTUAL_C seems to be present up to V7 so maybe this is a similar.
Can I also suggest after loading the updated firmware starting with the minimum options, just OPTION SYSTEM SPI, OPTION GUI CONTROLS 10 and OPTION LCDPANEL to see if it works, the program above might be a good first test.
Regards, Lyle.
Edited 2026-11-08 12:37 by mozzie
OA47
Posted: 03:18am 08 Nov 2026
Lyle, I can run your code with all options loaded, but when I load my code the error returns. I am very confused.
OA47
Confusion averted. I found that GUI code was accessed more than once that explains everything.
Thank you for your help in the diagnosis.
OA47
Edited 2026-11-08 13:26 by OA47
mozzie
Posted: 12:05pm 08 Nov 2026
OA47, good to hear you got it sorted
Regards, Lyle.
Wölfi
Posted: 01:26pm 08 Nov 2026
Clear_Flash_ALL.zip
Thanks from me too.
I hadn’t seen this collection before. But generally, this one has always helped me so far:
https://thebackshed.com/forum/ViewTopic.php?TID=19203&PID=260799#260799#260799
