Local Time 21:21 15 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : File odd behavior tftp mmb4w
crez
Posted: 07:52am 15 Nov 2026
Hi
I am creating a log file which consists of 4 bytes indicating the file size, then little-endian 16 bit signed integers from then on. Created on Webmite 2350a, 6.03.
I transfer these to the PC using command line "tftp -i xxxx get" command. MMB4W (used as a graphing tool) will not open the file. I open the file using HxD hex editor and then 'save as' to a different file name. MMB4W will open the new file. HxD hex editor has a compare function, and says the original and new file are the same.
I just tried copying the original file in the command prompt and that also produces a version that MMB4W is happy to read, but renaming the file does not.
On a different pico I was saving the same file type to an SD card and moving them to the PC that way without problems.
Any ideas what is going on?
crez
Posted: 08:16am 15 Nov 2026
UPDATE
I tried using tftp 192.168.... instead of tftp -i 192.168.... and that seems to work. Now I'll do some reading to find out why!
