Forum Index : Microcontroller and PC projects : Stumped again, this time with PIO
| OA47 Guru Joined: 11/04/2012 Location: AustraliaPosts: 1068 |
I have written code with MMBasic version 6.2 so a pi pico 2350 can generate a TTL serial stream from 300 baud to 921600 baud with options of parity, bit length and stop bits and output on GP0. I wanted to be able to sniff a running stream and hopefully analyse the stream and derive the baud rate and bits. I tried using straight basic but it was not quick enough to identify the higher speeds. Not having any expertise with PIO programming I asked AI for some help to write a subroutine using PIO to hopefully achieve identifying the stream. AI supplied some code which needed some modification (sometimes it confused PIO and PIN commands and it did not realise that PIO 1 cant be used on the 2350) Here is the code: Dim K$ ' Ensure GP1 is configured for PIO0 before calling: SetPin GP1, PIO0 Print "Press any key to start detection" Do K$=Inkey$ If K$ <> "" Then AnalyzeSerialGP1 Loop Sub AnalyzeSerialGP1() Local INTEGER pio_clk = 10000000 ' 10 MHz PIO clock (100 ns resolution, handle s 300 to 921600 baud) Local INTEGER i, count, raw_val, min_ticks = 99999999 Local INTEGER samples(127), state(127), bits(512), bit_idx = 0 Local FLOAT bit_ticks, baud_calc ' PIO0 SM0 Assembly (16-bit hex opcodes): ' Measures Low pulse width then High pulse width on JMP pin (GP1) Dim INTEGER pio_prog(7) = (&HA02B00C3, &H0041A0C1, &H8000A02B, &H00C80009, &H0 046A0C1, &H80000000, 0, 0) PIO STOP 0, 0 PIO CLEAR 0 PIO PROGRAM 0, pio_prog() ' Configure PIO0 SM0: clock = 10MHz, IN pin = GP1 (1), JMP pin = GP1 (1) PIO INIT MACHINE 0, 0, pio_clk, Pio(PINCTRL 0, 0, 0, GP1,GP1 ), , , 0 Print "Waiting for serial traffic on GP1..." ' Wait for line to be idle (High) first, then start SM0 Do While Pin(GP1) = 0 : Loop PIO START 0, 0 ' Collect 64 pulse durations (32 Low/High pairs) with a 5-second timeout Timer = 0 count = 0 Do While count < 64 And Timer < 5000 If Pio(FLEVEL 0, 0, RX) > 0 Then PIO READ 0, 0, 1, raw_val ' Each loop iteration in PIO takes 2 clock cycles samples(count) = (&HFFFFFFFF - raw_val) * 2 state(count) = count Mod 2 ' 0 = Low pulse, 1 = High pulse If samples(count) > 0 And samples(count) < min_ticks Then min_ticks = samples(count) EndIf count = count + 1' :Print count EndIf Loop PIO STOP 0, 0 If count < 10 Then Print "Timeout: Insufficient serial data detected on GP1." Exit Sub EndIf ' 1. Calculate and snap Baud Rate baud_calc = pio_clk / min_ticks Local INTEGER std_bauds(11) = (300, 1200, 2400, 4800, 9600, 19200, 38400, 5760 0, 115200, 230400, 460800, 921600) Local INTEGER best_baud = 0, b Local FLOAT min_err = 9999999.0, err For b = 0 To 11 err = Abs(baud_calc - std_bauds(b)) / std_bauds(b) If err < min_err Then min_err = err best_baud = std_bauds(b) EndIf Next b bit_ticks = pio_clk / best_baud ' 2. Reconstruct raw bitstream from pulse durations For i = 0 To count - 1 Local INTEGER num_bits = Cint(samples(i) / bit_ticks) If num_bits > 30 Then num_bits = 30 ' Cap inter-character idle gaps Local INTEGER k For k = 1 To num_bits If bit_idx <= 512 Then bits(bit_idx) = state(i) bit_idx = bit_idx + 1 EndIf Next k Next i ' 3. Analyze frame spacing (Distance between Start bits) ' Search for a long idle High (>= 11 bits) followed by a Start bit (0) Local INTEGER frame_len = 0, ones_run = 0 For i = 0 To bit_idx - 1 If bits(i) = 1 Then ones_run = ones_run + 1 Else If ones_run >= 11 Then ' Found clean Start bit at index i; measure until idle returns Local INTEGER j, ones_after = 0 For j = i + 1 To MIN(bit_idx - 1, i + 15) If bits(j) = 1 Then ones_after = ones_after + 1 If ones_after >= 3 Then ' Frame ended; subtract extra idle stop bits beyond 1 frame_len = (j - i) - (ones_after - 1) Exit For EndIf Else ones_after = 0 EndIf Next j If frame_len > 0 Then Exit For EndIf ones_run = 0 EndIf Next i ' 4. Evaluate Parity across captured frames Local INTEGER even_ok = 1, odd_ok = 1, frames_checked = 0 If frame_len >= 10 And frame_len <= 12 Then i = 0 Do While i + frame_len < bit_idx If bits(i) = 0 And bits(i + frame_len - 1) = 1 Then ' Valid Start (0) and Stop (1) framing Local INTEGER parity_sum = 0, d_end = i + frame_len - 3 For j = i + 1 To d_end parity_sum = parity_sum Xor bits(j) Next j Local INTEGER p_bit = bits(d_end + 1) If (parity_sum Xor p_bit) <> 0 Then even_ok = 0 If (parity_sum Xor p_bit) <> 1 Then odd_ok = 0 frames_checked = frames_checked + 1 i = i + frame_len Else i = i + 1 EndIf Loop EndIf ' 5. Report Derived Parameters Print "--- GP1 Serial Analysis (PIO0) ---" Print "Measured Baud : "; Cint(baud_calc); " -> Standard: "; best_baud; " bps" Print "Frame Width : "; frame_len; " bits (inc. Start & 1 Stop)" If frames_checked >= 2 And (even_ok = 1 Or odd_ok = 1) Then If even_ok = 1 Then Print "Parity : EVEN" If odd_ok = 1 Then Print "Parity : ODD" Print "Data / Stop : "; frame_len - 3; " data bits, 1 stop bit" Else Print "Parity : NONE" If frame_len = 11 Then Print "Data / Stop : 8 data bits, 2 stop bits (or 8-bit + Parity)" Else Print "Data / Stop : "; frame_len - 2; " data bits, 1 stop bit" EndIf EndIf End Sub The code times out without seeing any pulses and times out after 5 seconds with another Pi Pico generating a continuous stream. As I have mentioned I do not have a grasp of PIO programming and I was wondering if the brainier people on the forum could see where the code is going wrong. OA47 |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6276 |
Hi OA, As AI to disassemble this: Dim INTEGER pio_prog(7) = (&HA02B00C3, &H0041A0C1, &H8000A02B, &H00C80009, &H0 046A0C1, &H80000000, 0, 0) Then we can help you.... Volhout PicomiteVGA PETSCII ROBOTS |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3453 |
Could DEVICE SERIALRX do what you want? |
Voltout here is the description of the PIO program, ' PIO1 SM0 Assembly (16-bit hex opcodes): ' Measures Low pulse width then High pulse width on IN pin 0 (GP1) ' 0: MOV X, ~NULL (0xA02B) - Load X with 0xFFFFFFFF ' 1: JMP PIN, 3 (0x00C3) - If GP1 is High, Low pulse ended ' 2: JMP X--, 1 (0x0041) - Decrement X and loop while Low ' 3: MOV ISR, X (0xA0C1) - Move remaining count to ISR ' 4: PUSH noblock (0x8000) - Push Low count to RX FIFO ' 5: MOV X, ~NULL (0xA02B) - Reset X to 0xFFFFFFFF ' 6: JMP PIN, 8 (0x00C8) - If GP1 is still High, keep counting ' 7: JMP 9 (0x0009) - GP1 went Low, High pulse ended ' 8: JMP X--, 6 (0x0046) - Decrement X and loop while High ' 9: MOV ISR, X (0xA0C1) - Move remaining count to ISR ' 10: PUSH noblock (0x8000) - Push High count to RX FIFO ' 11: JMP 0 (0x0000) - Wrap to start OA47 |
Phil, could you show me a snippet of code that shows the use of DEVICE SERIALRX ? OA47 |
A crude test using PWM as a source of serial "UUU" characters and Device SERIALRX as the "serial sniffer" A better serial source would be another Pico running Device SERIALTX. > LIST Dim istring$, timeout_in_ms=2000, status% SetPin gp3, din 'serial sniffer pin SetPin gp4, pwm 'link pins GP3 & 4 PWM 2,19200/2,50 do : loop until pin(gp3)=0 do : loop until pin(gp3)=1 'ensure correct start - idle high Device SERIALRX gp3, 19200, istring$, timeout_in_ms, status% ,8 Pause 999 Print "Status ";status%, "Data ";istring$, Len(istring$) End > > RUN Status 2 Data UUUUUUUU 8 > Some time ago Volhout wrote a PIO_UART program that you may be able to adapt. PIO_UART . Some time wasting. Dim istring$, timeout_in_ms=1000, status% SetPin gp3, din SetPin gp4, pwm Sub Rx_test Do : Loop Until Pin(gp3)=0 Do : Loop Until Pin(gp3)=1 Device SERIALRX gp3, 19200, istring$, timeout_in_ms, status% ,64 Pause 999 Print "Status ";status%, "Data ";istring$, Len(istring$) End Sub PWM 2, 19200 / 2, 50 Rx_test PWM 2, 19200 / 4, 75 Rx_test End > > RUN Status 2 Data UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU 64 Status 2 Data wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww 64 > Edited 2026-11-20 20:19 by phil99 Footnote added 2026-11-21 09:41 by phil99 More time wasting. Scanning baud rates. The limitations of my fake serial source soon show up. RP2040 @ 400MHz. Dim istring$, timeout_in_ms=2100, status%, bd%=300, n% SetPin gp3, din SetPin gp4, pwm For n% = 0 To 12 PWM 2, bd% / 4, 75 Pause 100 Do : Loop Until Pin(gp3)=0 Do : Loop Until Pin(gp3) Device SERIALRX gp3, bd%, istring$, timeout_in_ms, status% ,50 Print "Baud";bd%, "Status";status%, "Data ";istring$, Len(istring$) If bd% < 70000 Then Inc bd%,bd% Else Inc bd%,38400 EndIf ' Print "Baud";bd%, Next End > RUN Baud 300 Status 2 Data wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww 50 Baud 600 Status 2 Data wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww 50 Baud 1200 Status 2 Data wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww 50 Baud 2400 Status 2 Data wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww 50 Baud 4800 Status 2 Data wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww 50 Baud 9600 Status 2 Data wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww 50 Baud 19200 Status 2 Data wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww 50 Baud 38400 Status 2 Data wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww 50 Baud 76800 Status 2 Data wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww 50 Baud 115200 Status 2 Data wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww 50 Baud 153600 Status 2 Data ÷÷÷ww··÷÷÷www·÷÷÷÷www·÷÷÷÷÷ww··÷÷÷÷÷ww··÷÷÷www···÷ 50 Baud 192000 Status 2 Data wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww 50 Baud 230400 Status-1 Data 0 |
Hi Phil, The PIO UART was written specifically for OA47. He may have tried it already and decided to use AI for a better solution. But thank you for your help in suggesting serial TX/RX. That is easier (embedded in MMBasic) than PIO. Volhout Edited 2026-11-20 20:38 by Volhout PicomiteVGA PETSCII ROBOTS |
