Local Time 14:55 28 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Coming soon to a CMM2 near you - Basic multi-tasking
Posted: 12:43pm 25 Nov 2026
Colour Maximite 2: threads for MMBasic, an overview
25 November 2026. Work in progress: threads are not in any release yet, and the details may still change. Comments and ideas are welcome.
MMBasic has long had interrupts: something happens, a short routine runs, and the program carries on. Threads are a different tool. A thread is an ordinary SUB that runs alongside the main program for as long as it likes, with its own loops, its own LOCAL variables and its own PAUSEs. The firmware shares the processor between the threads, a millisecond at a time.
Option Explicit
Dim Integer beats
Sub Heart
   Inc beats
   Pause 500                 ' the rest of the program runs meanwhile
End Sub
Thread Start 1, Heart
 Text 0, 0, "Beats: " + Str$(beats) + "  "
 Pause 100
Loop Until Inkey$ <> ""
End                           ' the threads stop with the program
What works today
These run on a test board now:
• THREAD START n, sub starts thread n (1 to 16) running a SUB. The main program is thread 0.
• THREAD EXIT ends the thread that runs it. A thread also ends when its SUB ends.
• THREAD YIELD gives up the rest of the thread's time slice.
• THREAD STOP n ends thread n where it stands. Its local variables and memory are freed.
• THREAD PAUSE n and THREAD RESUME n hold thread n and let it go on.
• THREAD SLICE ms sets the time slice, 1 to 100 ms. It is 1 ms unless you say otherwise.
• THREAD SIZE kb [, locals] sets the stack and the number of local variables for threads started after it.
• MM.INFO(THREAD) is the number of the thread that runs it. MM.INFO(THREAD n) is 0 if thread n is not running, 1 if it is running, 2 if it is in a PAUSE and 3 if it has been paused.
Still to come: locks (THREAD LOCK and UNLOCK), THREAD HOLD and RELEASE for a few statements that must not be split, THREAD WAIT (for a thread to end, or for a flag), arguments for a thread's SUB, and THREAD LIST.
How they work
• One thread runs at a time, and the switch comes only between statements, never in the middle of one. A statement is always whole: Inc count in two threads never loses a count.
• The threads take turns, 1 ms each, in number order. A thread whose PAUSE has just ended goes next, so things that are timed stay on time among busy threads.
• Each thread has its own LOCAL variables, FOR and DO loops, SUB and FUNCTION calls, GOSUBs, ON ERROR setting with MM.ERRNO and MM.ERRMSG$, and place in the DATA for READ. Two threads can run the same SUB at the same time, each with its own locals, recursion included.
• Everything else is shared: global variables and arrays, STATIC variables, the screen with its current colours, font and print position, open files, sound, the pins and the options.
• PAUSE in a thread costs nothing. The other threads run meanwhile, and a program whose threads are all waiting is idle.
• Interrupts work as before (SETTICK, SETPIN, ON KEY and the rest). Their routines always run in the main program, whichever thread was running when the interrupt came, and no thread runs until the routine returns.
• END in any thread, an error in any thread, or Ctrl-C stops the whole program. An error says where it was: "Error in thread 3, line 5".
• OPTION COMPILE ON works with threads.
• The cost: a program that starts no thread runs as fast as before. A switch takes about 5 microseconds, so 1 ms slices cost about half a percent. A thread takes about 37 KB of memory while it runs, given back when it ends.
What they cannot do
• They do not make a program faster. There is one processor: four busy threads get a quarter of it each. Threads are for doing several things at once, not for doing one thing sooner.
• They cannot cut into a statement. A statement that takes a long time (a SORT of a large array, a file copy, loading a picture, INPUT waiting for the user) holds every thread until it is done. For now PAUSE is the only wait that lets the others run, so read keys with INKEY$ in a loop, not with INPUT. Later INPUT and the other commands that wait will let the others run too.
• No priorities. Every thread that is ready gets its turn.
• No arguments for the thread's SUB yet. Until there are, MM.INFO(THREAD) tells a SUB which thread it is, to pick its row of an array (the second example).
• Limits: with the usual sizes a thread can go about nine FUNCTIONs deep (SUB calls take nothing) and have 48 local variables, and about ten threads can run at once. THREAD SIZE changes that: more stack for deep recursion, or fewer locals each for all sixteen threads.
• Not allowed in a thread: RUN, CHAIN, FLASH RUN, LIBRARY LOAD, MsgBox() and GUI CLICK. Not allowed while any thread is running: ERASE, REDIM, CLEAR, SAVE CONTEXT and LOAD CONTEXT. THREAD START is for programs, not the command prompt, and CONTINUE does not work after Ctrl-C in a program with threads.
The one thing to watch: what the threads share
A switch can come between any two statements. Suppose two threads do this:
' thread 1                    ' thread 2
Colour RGB(red)               Colour RGB(green)
Print "Alarm!"                Print "All well"
If the switch comes after thread 1's COLOUR, "Alarm!" is printed in green. Until the locks arrive there are three simple ways round it:
• One owner. One thread does all the drawing, or all the writing to a file, and the others only set variables for it.
• One statement. Text x, y, "Alarm!", , , , RGB(red) carries its colour with it, and nothing can come between.
• One writer. A variable that one thread sets and the others only read is always safe.
A test and the action after it are two statements, so If free > 0 Then free = free - 1 can be cut in the middle when two threads run it. Inc, and a single assignment, cannot.
Ideas for using them
• Something with a rhythm of its own: a clock in the corner, a heartbeat LED, a status line, a tune played note by note with a PAUSE between the notes while the game goes on.
• Straight-line code in place of a state machine: traffic lights, a sequence of valves and timers, an alien that moves, waits and fires. Each is written as steps with PAUSEs between them, not as a SETTICK routine and a variable that remembers where it had got to.
• Many of the same thing: every ball, alien or robot is the same SUB in a thread of its own, with its own LOCALs (the second example).
• A long job with a live screen: a Mandelbrot or a big calculation runs in a thread while the main program shows progress and reads the keys, and can pause it, let it go on or stop it (the third example).
• Logging: one thread samples a sensor every 100 ms into an array, another writes the array to the SD card every ten seconds, and the main program draws the graph.
• Communications: a thread watches a COM port or the network, puts the lines together and leaves each one in a global for the main program.
• A timeout: a thread that waits five seconds and then sets a flag, or stops another thread.
Thread or interrupt? An interrupt is for something that happens and wants a quick, short answer. A thread is for something that goes on: it waits, loops and has a flow of its own. They work well together: the interrupt sets a variable and a thread acts on it.
Two more examples
Four balls, one SUB. Each thread runs Ball with its own x, y, dx and dy. Each CIRCLE carries its own colour, so the threads cannot mix them up.
Option Explicit
Dim Integer i
Dim Integer col(4) = (0, RGB(red), RGB(green), RGB(yellow), RGB(cyan))
Sub Ball
 Local Integer me = MM.Info(Thread)
 Local Float x = 100 * me, y = 60 * me, dx = 2 + me, dy = 1 + me
   Circle x, y, 5, 1, 1, 0, 0                    ' rub the old one out
   x = x + dx : y = y + dy
   If x < 10 Or x > MM.HRes - 10 Then dx = -dx
   If y < 10 Or y > MM.VRes - 10 Then dy = -dy
   Circle x, y, 5, 1, 1, col(me), col(me)
   Pause 20
End Sub
CLS
For i = 1 To 4 : Thread Start i, Ball : Next
Do : Pause 50 : Loop Until Inkey$ <> ""
End
A long job that listens. The picture is drawn by a thread. The main program reads the keys: P pauses the drawing, R lets it go on, Q stops it.
Option Explicit
Dim Integer done, row
Dim k$
Sub Picture
 Local Integer x, y
 For y = 0 To MM.VRes - 1
   For x = 0 To MM.HRes - 1
     Pixel x, y, RGB(x And 255, y And 255, (x Xor y) And 255)
   Next
   row = y
 Next
 done = 1
End Sub
CLS
Thread Start 1, Picture
Do While done = 0
 k$ = UCase$(Inkey$)
 If k$ = "P" Then Thread Pause 1
 If k$ = "R" Then Thread Resume 1
 If k$ = "Q" Then Exit Do
 Pause 50
Thread Stop 1                 ' (does nothing if the thread has ended)
Print @(0, 0) "Ended at row"; row
PhenixRising
Posted: 02:21pm 25 Nov 2026
Another dream come true   I would have been ecstatic with four or eight but sixteen is even better
I have always used the state-machine approach which is still a nice solution but PAUSE needs to be a non-blocking timer. Threads are more like true multi-tasking. Fantastic
PhenixRising
Posted: 02:59pm 25 Nov 2026
First thought: Can the stepper interrupt still run?
Posted: 03:00pm 25 Nov 2026
  Quote   Interrupts work as before (SETTICK, SETPIN, ON KEY and the rest). Their routines always run in the main program, whichever thread was running when the interrupt came, and no thread runs until the routine returns.
If you mean the underlying H/W interrupt, those are completely unaffected
Edited 2026-11-26 01:01 by matherp
LeoNicolas
Posted: 03:13pm 25 Nov 2026
I can foresee some race condition bugs that will come to haunt developers
Jokes aside, I never thought I would see threads on the BASIC language
Amazing jobs Peter
Posted: 03:23pm 25 Nov 2026
Hi Peter,
Some 5 years ago I asked Geoff for "multi tasking" since PICAXE offers this (max 4 threads) on some devices. (i.e. 20M2).
@37k per thread, this is a no-go for the non-PSRAM pico's.
Posted: 03:28pm 25 Nov 2026
This one has been on my to-do list forever but whereas the AI can analyse the whole of MMbasic to plan the approach, that is probably beyond me holding it all in my head at once.
The beauty of the approach is already yielding real benefits in my dev testing. Start a thread to get user input with the INPUT or LINE INPUT routines which are currently completely blocking and now other processing can carry on. Reading from a ds18b20 is no longer blocking if it is read in a thread etc....
Posted: 03:41pm 25 Nov 2026
  Quote  @37k per thread, this is a no-go for the non-PSRAM pico's.
At the moment this is a cmm2 only capability however, if it will translate to the PicoMite at all then the memory usage can be already be tuned using:
THREAD SIZE kb [, locals] sets the stack and the number of local variables for threads started after it. The stack can be quite low if the thread isn't itself calling many nested subroutines and if it doesn't use many locals. The final code will also allow setting stack and local parameters on a per thread basis.
I see no reason it couldn't be fully usable on an RP2040 let alone an RP2350
PhenixRising
Posted: 06:16pm 25 Nov 2026
  Quote  • The threads take turns, 1 ms each, in number order. A thread whose PAUSE has just ended goes next, so things that are timed stay on time among busy threads.
Slick
Re: RP2350.
I am using all eight PIDs and all at the same rate. It just feels a bit clunky, having them in separate ISRs (latency?).
If we had this 1ms thread on the PicoMite, would I get the same priority? Thinking about doing all PIDs in one CSUB.
bfwolf
Posted: 08:24pm 25 Nov 2026
Do you plan to add methods for inter-thread communication or thread synchronization, such as messages, semaphores, or mutexes?
Many of these can be implemented using counting semaphores (with a defined maximum value) — e.g. mutexes can then be created by limiting a counting semaphore to values ​​of 0 and 1.
If I recall correctly, most synchronization tools in FreeRTOS are ultimately built using just a few basic primitives.
Regards.
Posted: 08:59pm 25 Nov 2026
  bfwolf said  Do you plan to add methods for inter-thread communication or thread synchronization, such as messages, semaphores, or mutexes?
As most statements are atomic (actioned completely once started) you already have all that's needed I think.
bfwolf
Posted: 09:27pm 25 Nov 2026
Not when interacting with hardware, e.g. writing to GPIOs..
Or e.g. when accessing the same file and seeking to positions.. => Mutex
Many jobs need more than 1 BASIC statement.
bfwolf
Posted: 10:01pm 25 Nov 2026
some things you have to code yourselves
Posted: 10:16pm 25 Nov 2026
bfwolf
At least one kind of non-busy interlock would be wise, for sure.
Posted: 07:44am 26 Nov 2026
set/reset a system flag?
Posted: 08:29am 26 Nov 2026
Here is the threads manual for review/comment. It should answer many of the questions
Colour_Maximite_2_Threads_User_Manual.pdf
AlbertR
Posted: 10:42am 26 Nov 2026
I have to say that the fantastic developments that have been put together here in such a short time are a little intimidating. I can only marvel at it all and express my sincere admiration for everyone driving this forward, especially Peter(When on earth does he find the time to do all that? ), who is doing an incredible job here. I can barely keep up with everything and feel like I can’t contribute anything. Someone here on the forum once said it’s like being in a candy store—you bounce back and forth excitedly, marveling at everything, and I’m already getting a little dizzy from all the sugar.
I was just about to post my cooperative scheduler for discussion before yesterday, then I saw this thread   . Now I'm just sharing it for informational purposes. It's based on jobs, and the math functions helped speed them up quite a bit.
I adapted Peter's examples for this.
Option explicit
Option default none
'- Scheduler-consts -----------------------------------------------------------|
Const MaxEntry = 16     ' num of Job-Slots variable
Const QueMask  = 15     ' num of Queue-slots - 1; have to be 2^n - 1
Const MaxTOut  = 15     ' max Soft-Timeouts
Const KFree = 1e30      ' Mark Slot free(float)
Const KRun  = 5e29      ' Mark Slot still in use(float)
Const KPAUS = &hfffffffffff0' Mark Slot paused(int)
Const E_LISTFULL = 1    ' id MaxEntry reached
Const E_QUEFULL  = 2    ' id Queue overrun
Const E_NOSLOT   = 3    ' id JobNext by no Job in List
'- Scheduler-Variablen --------------------------------------------------------|
Dim float   JKey(MaxEntry-1)                 ' to time / KFree / KRun
Dim integer JArg(MaxEntry-1)                 ' Job-parameter( use not spezific)
Dim JFunc(MaxEntry-1) As string length 20    ' Sub-Name (max. 20 char)
Dim QFunc(QueMask)    As string length 20    ' Queue: Sub-name
Dim integer QArg(QueMask)                    ' Queue: Par
Dim float   TDue(MaxTOut)       ' Soft-Timeouts: expiration time (KFree = inactiv)
Dim integer ErrCnt(3)           ' error-counter
Dim integer SchedRun            ' state of sequencer 0=stop
Dim integer CurSlot             ' Slot of runnung Job (-1: eject Job)
Dim integer col(4) = (0,RGB(red),RGB(green),RGB(yellow),RGB(cyan))
Type circle_atr
 x As float
 y As float
 dx As float
 dy As float
End Type
Dim cir(4) As circle_atr
Dim integer res, i, row
'- start ----------------------
JobListInit ' allways the first step: init the Joblists
JobAdd "KeyCheck", 0, 0
JobAdd "Picture", 1, 0
CLS
Sequencer() ' start scheduler
res = JobRemove("Picture", -1)' or JobListInit
Pause 2000
CLS
For i = 1 To 4
cir(i).x = 70*i:cir(i).y = 50*i:cir(i).dx = 2+i: cir(i).dy = 1+i
JobAdd "Ball", i, 0
Next
Sequencer() ' start
Print @(0, 0) "Demo ended"
End
'- Jobs -----------------------------------------------------------------------|
Sub Ball(i As integer)
 JobNext i, 20 ' plan an other turn; without this the Job ends here
 Circle cir(i).x, cir(i).y, 5, 1, 1, 0, 0 ' rub the old one out
 cir(i).x = cir(i).x + cir(i).dx : cir(i).y = cir(i).y + cir(i).dy
 If cir(i).x < 10 Or cir(i).x > MM.HRES - 10 Then cir(i).dx = -cir(i).dx
 If cir(i).y < 10 Or cir(i).y > MM.VRES - 10 Then cir(i).dy = -cir(i).dy
 Circle cir(i).x, cir(i).y, 5, 1, 1, col(i), col(i)
End Sub
Sub Picture(id%)
Static integer y = 0
Local Integer x
For x = 0 To MM.HRES - 1
Next
Inc y
row = y
If y < MM.VRES Then
  JobNext id%, 0' as soon as possible
Else
  SchedStop
EndIf
End Sub
Sub KeyCheck(par%)
Local string k$
 JobNext 0, 50
 k$ = UCASE$(Inkey$)
 If k$ = "P" Then JobRetrig("Picture", 1, KPAUS )
 If k$ = "R" Then JobRetrig("Picture", 1, 0)
 If k$ = "Q" Then SchedStop
'If Inkey$ <> "" Then SchedStop
End Sub
'== sequencer ================================================================|
Sub JobListInit()
 Local integer i
 For i = 0 To MaxEntry-1
   JKey(i) = KFree
 Next
 For i = 0 To 3
   ErrCnt(i) = 0
 Next
 For i = 0 To MaxTOut
   TDue(i) = KFree
 Next
 SchedRun = 1
 CurSlot = -1
 Timer = 0
End Sub
'insert(start) Job with time-slot (delay in ms, 0 = next turn)
Sub JobAdd(func$, par%, delay%)
Local integer gFi
Local float   gFv
 gFv = Math(Max JKey(), gFi)      ' greatest value = Slot free
 If gFv < KFree Then Inc ErrCnt(E_LISTFULL): Exit Sub  ' no Slot free
 JKey(gFi)  = Timer + delay%
 JFunc(gFi) = func$
 JArg(gFi)  = par%
End Sub
' running Job plans himself ones more (reuse Slot).
Sub JobNext(par%, delay%)
 If CurSlot < 0 Then Inc ErrCnt(E_NOSLOT): Exit Sub
 JKey(CurSlot) = Timer + delay%
 JArg(CurSlot) = par%
End Sub
' remove all Jobs with name func$ (and Parameter = par%; par% = -1: all)
Function JobRemove(func$, par%) As integer
 Local integer cnt, i
 cnt = 0
   If JKey(i) < KRun Then
     If JFunc(i) = func$ And (par% = -1 Or JArg(i) = par%) Then
       JKey(i) = KFree
       Inc cnt
     End If
   End If
 Next
 JobRemove = cnt
End Function
'give an exiting Job a new expire-time
Sub JobRetrig(func$, par%, delay%)
 Local integer i
     If JFunc(i) = func$ And JArg(i) = par% Then
       JKey(i) = Timer + delay%
       Exit Sub
     End If
   End If
 Next
 JobAdd func$, par%, delay%
End Sub
' Timeout starten bzw. neu starten (Retrigger)
Sub SetTimeOut(idx%, delay%)
 TDue(idx%) = Timer + delay%
End Sub
Sub CancelTimeOut(idx%)
 TDue(idx%) = KFree
End Sub
' 1 = abgelaufen (in zeitkritischen Tasks direkt: If TDue(idx) <= Timer Then ...)
Function TimedOut(idx%) As integer
 TimedOut = (TDue(idx%) <= Timer)
End Function
Sub Sequencer
 Local integer p1, mi
 Local float fv, t0
 Local nm As string length 20
 SchedRun = 1
   fv = Math(Min JKey(), mi)
   If fv < Timer Then ' because of float equal is unlikely
     JKey(mi) = KRun  ' mark running, decide about FREE later
     CurSlot = mi
     Call JFunc(mi), JArg(mi)
     If JKey(mi) = KRun Then JKey(mi) = KFree ' no JobNext -> make Slot free
   End If
 Loop Until SchedRun = 0
End Sub
Sub SchedStop
 SchedRun = 0
End Sub
Albert
bfwolf
Posted: 10:44am 26 Nov 2026
  matherp said  Here is the threads manual for review/comment. It should answer many of the questions
I’ve taken a "quick" look through the manual: it seems to contain everything necessary for thread synchronization.
With "THREAD HOLD" and "THREAD RELEASE," one can temporarily block thread switching — useful, for instance, when combining flags with other data structures, such as  implementing a ring buffer for messages using arrays of strings.
It would be helpful if "THREAD WAIT FLAG f [, timeout]" also implicitly performed a "THREAD RELEASE" in cases where the same thread had previously executed "THREAD HOLD". That would make the entire operation "atomic." Perhaps this is already the case, but simply not yet documented?
And by the way:
Regards, bfwolf.
Posted: 10:50am 26 Nov 2026
Thanks for reading it so closely. At the moment THREAD WAIT FLAG inside THREAD HOLD is an error ("Cannot wait while the threads are held") unless the flag is already set; the manual says so under THREAD HOLD. You don't need it for a correct ring buffer, though: a flag stays set until a thread clears it, so if the consumer clears the flag inside its hold when it finds the buffer empty, then releases and waits, a message put in between still wakes it. What you describe, releasing the hold for the wait and taking it again on waking, is a condition variable, and it would make that pattern shorter and harder to get wrong. It's on the list for a later beta, and the next manual will have a worked queue example.
Posted: 01:29pm 26 Nov 2026
V8.00.00b5 now posted on the cmm2 beta thread including the full threads implementation
