Local Time 11:36 28 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Curious AutoRun quirk
Malibu
Posted: 10:36pm 25 Nov 2026
I've been working on some code the last couple of weeks... any changes to the code and I'll do an upload, The WebMite will go straight into autorun as it should because my settings are - OPTION AUTORUN  ON,NORESET
As expected and that's all good.
The last couple of days, for some reason the autorun is not working after an upload. It works after a W/D fires and also a power up, but now I need to type in the RUN command (or hit F2) for it to start running.
I'm using MMedit 5.4.3 with MMCC on a WebMite MMBasic RP2350A Edition V7.00.00RC7
I'm suspecting it's the code size.
I did 2 tests for autorun with these results ...
  Quote  ****** TEST 1 ******
Uploading using:  'target port\COM14:115200 s\picomite
Upload started
NEW
AUTOSAVE
Progress: 2400/2414
Enter ctrl-Z, F1, or F2 to exit
Time taken: 9257mS
Saved 90789 bytes
****** TEST 2 ******
Upload started
NEW
AUTOSAVE
Progress: 2200/2200
Time taken: 8411mS
Saved 82688 bytes
> RUN
Code Good
Test 1 is 2415 lines of code and comments and doesn't autorun, Test 2 is 2200 lines of code and comments, but will autorun. (Both are pretty much the same code; Test 2 is just an earlier version)
My suspicion is that the MMCC might be sending a RUN command before the WebMite is ready to receive it. Maybe it's still saving the file or otherwise busy in some way.
Is there a way that I can change the delay time before the RUN is sent?
Posted: 12:05am 26 Nov 2026
in MMCC.inf
about line 110 there is an option
Autosave end delay
increase that value to allow more time to process the file
Remember to have MMCC shut down when you alter the inf file
The 'RUN' that MMCC sends has nothing to do with AUTORUN options
Edited 2026-11-26 10:06 by TassyJim
Malibu
Posted: 12:54am 26 Nov 2026
Thanks Jim, that did the trick. I looked at the .inf file, but I didn't jerry that was the setting to change
