Local Time 14:55 28 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PS/2 mice on bottom socket of CMM2 with FW v7+.....
Posted: 12:21am 26 Nov 2026
Hi all.
Can anyone else here confirm for me please, that a plain old PS/2 mouse with the 6-pin plug, will work in FW v7 or higher?
With the mouse on a PS/2 to USB plug adapter, and it plugged into the bottom USB socket on the CMM2G2v2 board, if I use the command OPTION MOUSE 0 as per the manual page 59, the unit responds with an error that the mouse was not detected.
The EXACT same mouse, USB adapter and CMM2G2v2 board with FW v5, the mouse is detected and works fine.
What I need at this point, is someone else to test if they can get a PS/2 mouse to work on the bottom USB socket on the CMM2G2v2 with FW v7 or higher installed.
I am also going to try different PS/2 mice, but I only have the one of that type here at the moment, but it does work OK on v5 as I say - but not on v7, which is odd....
Posted: 05:21am 26 Nov 2026
Using a microsoft basic
> OPTION LIST
480MHz Colour Maximite 2 G2
MMBasic 8.00.00b2
CURRENT VGA mode 800x600 RGB332
CURRENT DISPLAY 50,100
OPTION USBKEYBOARD US
OPTION MOUSE 0,0
OPTION COMPILE ON
> LIST ALL
do
print mouse(X,0),mouse(Y,0)
pause 500
loop
> RUN
400     300
400     300
323     293
0       599
190     157
559     121
299     127
715     0
799     0
677     173
0       483
281     530
104     247
52      316
82      350
85      460
10      491
Make sure the mouse is plugged in when you apply power to the CMM2
Posted: 07:55am 26 Nov 2026
Thanks very much, Jim.
Must be something to do with my PS/2 mouse.
@ Peter: Was ANYTHING changed with respect to the PS/2 mouse code in the FW upgrade from v5 to v7?
I expect NOT, but if that was the case, why won't the mouse I am using under v5, NOT work on v7?
It does NOT make sense to me at all.
I will try other mice in the next few days, once I am able to get a hold of some original PS/2 mice and some USB(but PS/2 compatible) mice.
  Quote  Make sure the mouse is plugged in when you apply power to the CMM2
Never did this.
So used to hot-plugging USB!
Perhaps that is the issue - I will test, as I know that PS/2 is NOT hot-swap-able in general.
Edited 2026-11-26 18:03 by Grogster
Posted: 08:40am 26 Nov 2026
Hi Grogster,
I can confirm that my (Logitech) PS2 compatible USB mouse works on CMM2 G2 (the unit I purchased through you) with V8b4.
But the mouse needs to be plugged in before you power ON the CMM2. It does not hot-plug.
Posted: 11:54pm 26 Nov 2026
Thank you.
disco4now
Posted: 12:02am 27 Nov 2026
A USB mouse plugged in at the same time will take priority in the editor and gui controls.
From manual for OPTION MOUSE
a USB mouse plugged into the USB connector is
used by the editor and the GUI controls in place of the mouse set here
F4 H7FotSF4xGT
