Local Time 14:55 28 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Update a WebMite using a browser page
Malibu
Posted: 09:51pm 27 Nov 2026
Another great project by claude AI
From the ReadMe file :
  Quote  PICO WEB UPLOADER
Update a Raspberry Pi Pico (RP2350 WebMite, MMBasic V7) from a web page: send web files and whole new programs from a browser,
with checksums, a backup, one-button rollback, and optional ENCRYPTED program files.
FOLDERS
 1_Working_Example/        A complete, tested uploader. Put the program and the page on a Pico and it works.
                           Includes a 100 KB test program for trying big installs.
 2_Minimum_Starting_Base/  ONLY the updating code (no WiFi / web-server code), as a parts list to merge into your own web program.
                           (Never run on its own - see its README.)
 3_Encryption/             The PC tool that makes encrypted program files, sample keys and files, and a detailed description of how
                           the encryption works from end to end.
QUICK START (details in 1_Working_Example/README.txt)
 1. Put update_pico_Ver3.bas on the Pico and RUN it. Put upload.html on the Pico (exactly that name).
 2. Browse to http://<the Pico's IP>/
 3. Choose a file and press UPLOAD. For a program, then press INSTALL. ROLLBACK goes back.
The basic idea is that you have a WebMite running remote and it needs a new program update or some extra files.
Usually, you would need to plug in to a PC and upload the new code via a terminal program (I always use MMCC)...
That may be difficult in some situations, so this tool here allows remote reprogramming using a web-page upload. Run the web page on the WebMite, select the file to send and it all works the same as using a terminal program.
There's also an optional Encryption to keep your program code from prying eyes if needed.
Try it out, it could be useful for someone
There's lots of detailed README files in all the directories, and how-to examples
Working Example.zip
Minimum Files.zip
Encryption.zip
