Forum Index : Microcontroller and PC projects : Maximite Cheat Sheets
| Gizmo Admin Group Joined: 05/06/2004 Location: AustraliaPosts: 5193 |
OK, I figure its only a matter of time before we start to see some handy cheat sheets for the Maximite, so here's one to get started. Its a screen layout for the VGA output. Basically a bit of graph paper you can print out and draw your screen layout on before you start writing the program.
2011-06-12_200312_MaximiteVGAScreenMap.pdf I'll do up one for the composite output at a later date. When using the locate command to position text, remember it works differently from the old BASIC locate command. The Maximite's locate works like LOCATE X,Y where X and Y are pixels, from the top left corner. If you then PRINT, the first character will start to the right/underneath this point. You can position text in pixel steps, unlike the old BASIC where you could only position text on the standard text rows and columns. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| rhamer Senior Member Joined: 06/06/2011 Location: AustraliaPosts: 174 |
Reminds me of the one I did for my VZ200 about 30 years ago. Rohan Hamer HAMFIELD Software & Hardware Solutions Makers of the Maximite Expander. http://www.hamfield.com.au |
| BobDevries Senior Member Joined: 08/06/2011 Location: AustraliaPosts: 266 |
Hehe, those graph papers were included in the manuals for the Tandy Colour Computer, but I remember doing them for my DREAM 6800. Ah, the memories.... Regards, Bob Devries Dalby, QLD, Australia |
| Andrew_G Guru Joined: 18/10/2016 Location: AustraliaPosts: 901 |
OK then, this is NOT a competition but I've attached today's entry of a 800x600 VGA grid. It should open to an Excel file. Please feel free to enhance/fix it and submit it back here. CMM2 VGA Layout.zip Cheers, Andrew (could someone confirm that it unzips OK - thanks) |
| TrevorH Senior Member Joined: 06/04/2018 Location: United KingdomPosts: 145 |
It Does Trevor |
Thanks Trevor, Andrew |
