Local Time 08:21 13 May 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New Maximite MMBasic Version - V2.4
Posted: 01:07pm 13 Jun 2011
Hi folks,
Just letting you know that a new version of the Maximite firmware (including MMBasic) is available for download at http://geoffg.net/maximite.html#Downloads
This wraps up the fixes in the 2.3x test releases. The full list (from the change log) is:
Fixed an issue which caused glitches or noise on the video output while a BASIC program was running. This particular issue caused random horizontal lines of pixels to be intermittently shifted 8 pixels to the right when MMBasic was running a program (ie, not waiting for user input).
A bug which caused the unary negation function to fail has been fixed.
For example, PRINT –SIN(2) now works.
Fixed a bug which caused the RENUMBER command to miss renumbering a GOSUB embedded in an IF…THEN…ELSE command.
Fixed a bug which caused negative numbers in DATA statements to be returned as positive numbers. As a side result you can now use numeric expressions (eg, 8 * 60) in DATA statements.
The RUN “file” command now checks if “file” exists before clearing the program currently in memory. This means that if used with OPTION ERROR CONTINUE you can recover from an error when tying to run one program from within another.
The semicolon character (;) is now optional between expressions in the print statement.
For example, you can now use: PRINT “Voltage is “ x “mV”
This was added to improve Microsoft compatibility.
Updated the “Maximite User Manual” to V2.4 to include the new features listed above
thetinkerer
Posted: 07:33am 17 Jun 2011
Thanks Geoff for doing the update. I think all your good work is appreciated by many.
Marc
sparkey
Posted: 07:38am 17 Jun 2011
thanks frm sparkey
Talbit
Posted: 03:21am 20 Jun 2011
Geoff,
I'm having trouble implimenting the format$ command.
It returns with
Error: Unknown command
I tried going back to basics and just typed in format$(45) with the same error.
Should that print out 45 for me?
What am I doing wrong? I'm using V2.4
Thanks for your great work.
Talbit
Talbit
BobDevries
Posted: 03:24am 20 Jun 2011
Talbit,
you need to use PRINT FORMAT$(45)
Hope that helps
Bob Devries
Dalby, QLD, Australia
Talbit
Posted: 03:56am 20 Jun 2011
God, I'm stupid!
Thanks for your response.
Talbit
Talbit
Talbit
Posted: 04:27am 20 Jun 2011
Bob,
Not sure where to ask my questions but this will do I guesse! That worked fine.
I'm actually trying to build a basis clock (don't ask!)and have it ticking up okay. But I want to printout the clock on the one line. How can I suppress the line feed in my Print statement and have it overwrite on the one line rather than filling up the screen? I'll post my simple program if you want it.
Talbit
Talbit
stuarts
Posted: 04:41am 20 Jun 2011
If you dont want a linefeed, append a semicolon to the end of the print statement.
if you want to return to the start of the line to overwrite the line, have a chr$(13); at the end of your line and it will return the cursor to the start of the line to allow you to display the new data in the same place.
chr$(13) is a carriage return, no linefeed
Stuart
Time is nature's way of keeping everything from happening all at once.
Talbit
Posted: 04:57am 20 Jun 2011
Thanks Stuart,
Well that worked! Now how do I suppress the flashing cursor (which is flashing over the first character)?
Talbit
Talbit
Posted: 05:30am 20 Jun 2011
You could use LOCATE
10 cls
20 locate 200,200
30 print time$; " ";
40 pause 1000
50 goto 20
Talbit
Posted: 06:20am 20 Jun 2011
Gents,
Thanks for all your input. I can see where I was going wrong. I'm developing this on a laptop via the USB serial port. But when I hooked up a VGA screen it all fell into place. And boy, is this a trip down memory lane!
I know this wasn't the place to have asked this question. The forum looks a bit messy and is expanding at an alarming rate. Where should I have posted this question in the forum?
Talbit
Talbit
Posted: 06:27am 20 Jun 2011
Its fine to post new questions like this in this area of the forum. Just start a new post with a title like "Problem with PRINT command" or something like that, so anyone browsing can quickly get an idea what the post is about before reading it.
