Forum Index : Microcontroller and PC projects : maxi
| sparkey Senior Member Joined: 15/06/2011 Location: AustraliaPosts: 819 |
as i am a nebie here ...would it ever be possable for this machine to run a bais web browser...given tha fact that somebody would have to write the program for the browser and would it ever be possable to have a dial up modem interface for it i know this may be far in the distance but ......i have built my own solar /wind power system from my own back ..i bought a wind gene`r 600w 40 volt and designed my own inverter it runs modified sq wave i run 36 volt battrys at 250 a/h..... technicians do it with least resistance |
| Gizmo Admin Group Joined: 05/06/2004 Location: AustraliaPosts: 5193 |
I would say there would be no chance it could run any sort of web browser. Its just not that sort of machine. Besides, you can buy a netbook for close to $300 these days that will do that and much more, or ecen a 2nd hand laptop for $100. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| RossW Guru Joined: 25/02/2006 Location: AustraliaPosts: 495 |
This is my point about Ethernet, Glenn. The boards I've got run not only a webserver, but an ftp server and an SNMP server. Once you've got the basic TCP/IP stack, things to operate as a basic webserver are not terribly complex or difficult. For example: This little device includes not only the connector, the feromagnetics, couple of LEDs, but a complete webserver, DHCP client/server, telnet, terminal server, and RS232 interface, with a couple of megabytes of FLASH left over to store your application/web pages in! |
Hi Ross Sparky is looking for a web browser, not server. But thats a interesting little device
Doh! That'll teach me for reading and replying to forum messages while on the phone. (ok, it probably won't!) A very basic web browser wouldn't be too hard either. Displaying images (especially some of the more complex compression file formats) might be unreasonable though, as even trying to dither to make an acceptable greyscale would be unreasonable. But a text-only browser that stripped all the tags, displayed what it could (eg, might understand bold/italics tags and not much else), and allow following links, would probably be do-able. Just. |
donmck![]() Guru Joined: 09/06/2011 Location: AustraliaPosts: 1314 |
Or even $89 including postage and windows CE for a new one. http://www.ebay.com.au/itm/7-Mini-Cheap-Laptop-Notebook-Wi-F i-Netbook-Win-CE-6-0-/110699213237?pt=AU_Tablets&hash=item19 c62ff1b5 Cheers Don... https://www.dontronics.com |
thanks from sparkey i will look at that seems cool regards technicians do it with least resistance |
stuarts![]() Senior Member Joined: 15/06/2011 Location: AustraliaPosts: 199 |
Hey Don, there are always text based browsers..... Time is nature's way of keeping everything from happening all at once. |
I remember using some Stuart. Ends up like: Here is a picture [pic] of some bikini babes. Made me move from DOS to W3.11 Cheers Don... https://www.dontronics.com |
Don, I didn't say they were much fun to use. Just small. ;) Time is nature's way of keeping everything from happening all at once. |
