Forum Index : Microcontroller and PC projects : Script to connect, then set date and time
James_From_Canb![]() Senior Member Joined: 19/06/2011 Location: AustraliaPosts: 265 |
I downloaded the latest version (V4.69) of TeraTerm from Sourceforge. It's powerful. The script below sets the title of the terminal window, connects to the MaxiMite and sets the date and time. The macro language can also process screen output from the Maximite which looks interesting. Try this.... Cut and paste the script below to a file called start-mm.ttl. Change the number of the com port to the one you use. Save the file to somewhere easily accessible. Windows 7 is a pain in the proverbial for this sort of thing. I cannot save the macro file in the same directory as the program. It's good security, but difficult for older programs like this. I suggest saving it on a thumb drive, or any drive except C:. I tried my E: drive and I couldn't save it, but I could on my M: drive. Go figure. Create a new shortcut, or change the Target properties of the Tera Term icon to "C:\Program Files (x86)\teraterm\ttpmacro.exe" "m:\start-mm.ttl" Note that it's no longer starting Tera Term, it's starting the Tera Term macro program, which starts Tera Term and executes the commands. You'll have to change the drive letter / location of the macro from m:\ to whereever you saved the script. Now, when you click on the icon, it opens Tera Term and sets the time and date on the Maximite. Neat. Here's the script: ;; Tera Term Macro ;; ============================================================ ================ ;; file start-mm.ttl ;; ;; desc A startup macro for Tera Term, customised for the Maximite ;; ============================================================ ================ ;; HISTORY ;; ;; 2011-06-19 James Deakins ;; Original Version ;; ;; BASED ON CODE FROM ;; http://processors.wiki.ti.com/index.php/Teraterm_Scripts ;; ============================================================ ================ ;; ============================================================ ================ ;; DEFINITIONS ;; ============================================================ ================ ;; ;; COM port - >>> you will have to replace the 3 with your com port number <<< ;; myComPort = "3" ;; ;; Title of the Tera Term Window ;; StrWindowTitle = 'MaxiMite Terminal' ;; ;; Current Date ;; getdate CurDate "%d/%m/%Y" ;; ;; Current Time ;; gettime CurTime "%H:%M:%S" ;; ============================================================ ================ ;; CONNECT TO MAXIMITE, NAME TERMINAL WINDOW and UPDATE MAXIMITE DATE and TIME ;; ============================================================ ================ ;; ;; Connect ;; ------- myConnectString = "/C=" strconcat myConnectString myComPort connect myConnectString ;; ;; Set window title ;; ---------------- settitle StrWindowTitle ;; ;; Set the Date ;; Sendln 'DATE$="'CurDate'"' ;; ;; Set the Time ;; ------------ Sendln 'TIME$="'CurTime'"'M:\ My mind is aglow with whirling, transient nodes of thought careening through a cosmic vapor of invention. Hedley Lamarr, Blazing Saddles (1974) |
| Gizmo Admin Group Joined: 05/06/2004 Location: AustraliaPosts: 5168 |
Thats a handy tip James I'm using TeraTerm to talk to my Maxmite, so will try it out. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| Ray B Senior Member Joined: 16/02/2007 Location: AustraliaPosts: 219 |
Great hint James but the macro has an error that causes the time to not be set when first plugged into USB and run. When I enter 'print time$' the clock is zeroed but 'print date$ 'is OK If you go into TeraTerm and go Control / Macro then select your macro and open it it comes back with error: Variable Not Initilized Sendln 'TIME$='"CurTime""M:\ To fix problem change line to following: Sendln 'TIME$='"CurTime"" Looks like the M:\ may be a typo or error from your editor Cheers RayB from Perth WA |
Yep - Agree. That's a typo or cut-and-paste error. Thanks for pointing that out Ray. Apologies to everyone who was caught by that. My mind is aglow with whirling, transient nodes of thought careening through a cosmic vapor of invention. Hedley Lamarr, Blazing Saddles (1974) |
