Local Time 23:01 25 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MaxiMite Current Consumption
Ray B
Posted: 10:49am 20 Jun 2011
Was looking at a battery backup arrangement for MaxiMite to retain Date / Time for a logging application - driving a basic MM without nothing else connected from 6 x 1.2 rechargables into the external power socket was pulling 120mA.
Thirsty little bugger....
RayB from Perth WA
donmck
Posted: 11:59am 20 Jun 2011
  Ray B said   Was looking at a battery backup arrangement for MaxiMite to retain Date / Time for a logging application - driving a basic MM without nothing else connected from 6 x 1.2 rechargables into the external power socket was pulling 120mA.
I would like to think that within 2 or 3 months there will be Real Time Clocks with battery backup, if you can wait that long Ray.
Cheers Don...
https://www.dontronics.com
Ray B
Posted: 01:09pm 20 Jun 2011
Don RTC is no longer a problem.... see James post "Script to connect, then set date and time" for users of TeraTerm.
As soon as I switch on using USB date / time is set through a simple macro but yes this is just a work around until we have I2C working to DS1307 chips.
RayB from Perth WA
captainbill
Posted: 01:35pm 20 Jun 2011
Howdy
Dallas Semi ds1307, 2 pins, small breadboard, I2C software for the Maxi.
Dallas also makes temperature compensated high accuracy version.
Bill
Old school. Still interested. Head in the clouds.
Posted: 03:33am 21 Jun 2011
Hi
I have some PCB's for some of the popular RTC chips, with battery backup, waiting for the IIC commands though !
http://www.carnut.info/Trx-RTC/RTC.htm
This PCB was designed to fit on the back of a colour TFT display, also using IIC commands.
http://www.carnut.info/tftpcb/tft.htm
http://www.carnut.info/maximite/index.htm
VK3PE
Posted: 03:39am 21 Jun 2011
The DS1307 is limited in IIC speed to 100KHz I think, which may or may not be an issue.
glenn
VK3PE
