Local Time 11:42 08 Aug 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Compiling Maximite Firmware Source Code.
Jimbo
Posted: 11:09am 20 Jun 2011
Has anyone else tried to recompile the Maximite Firmware Source code and had a problem ?
I have downloaded the source code from the Web Page, and am trying to compile with MPLAB version 8.70, and MPLAB C32 Lite Version 1.12. I have tried all versions from V2.2 to V2.4, however I receive compile errors concerning the following two functions.
/* BSD library functions */
int strcasecmp (const char *s1, const char *s2) and
int strncasecmp (const char *s1, const char *s2, size_t n)
I notice that these functions are not included in the MPLAB C32 pic32-libs\string.h file, but are infact defined in the pic32-libs\lega-c\string.h file. So ultimately my build fails with a unresolved reference for these functions.
I have overcome the problem, by adding my own implementation for these two functions to the source code, but thought there might be an easier way. Compiler option or something to use these lega-c paths and libs instead.
Any suggestions or comments would be appreciated.
Jimbo.
haiqu
Posted: 12:58am 30 Jul 2011
Hi Jimbo,
From Source\Readme.txt:
"You should install Microchip MPLAB IDE V8.56 or later and Microchip C32 C Compiler V1.11B Student (or Lite) version. Note that the source does not seem to compile with a later version of the C32 Compiler (this will be investigated when time permits). In the meantime you can find V1.11B at the following location: http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_P AGE&nodeId=1406&dDocName=en023073 "
Cheers M8,
Rob
unzip, strip, touch, finger, grep, mount, fsck, more, yes, fsck, fsck, fsck, umount, sleep
seco61
Posted: 01:27am 30 Jul 2011
Hi Jimbo,
As mentioned above, the source currently will only compile with v1.11.
There were some significant changes in v1.12 (see the microchip release notes) and the Maximite source needs to be slightly re-worked to accomodate the changes.
regards
Gerard (vk3cg/vk3grs)
vasi
Very good job Jimbo, we can have your workaround?
Vasi
Elvish name: Mablung Miriel
Beyound Arduino Lang
Jimbo
Posted: 09:57am 31 Jul 2011
To Compile with C32 Lite Version 1.12
I added the missing functions myself. Just add the BSDFunctions.c to the project (Source) directort, and include the BSDFunctions.h file to stop the warnings.
I have been compiling with Version 1.12 this way since the start, and it seems to work ok. Just thought it shouldn't have been a problem. But now that I know about the differences between 1.11 and 1.12 I supose it's ok.
2011-07-31_195644_BSDFunctions.zip
wizard
Posted: 12:42pm 31 Jul 2011
hi all,
I am compiling and loading my pic32 with a totally open toolchain.
It consists of openwrt.org for atheros as done by villagetelco.org.
With a custom ld file. (One that you can actually read!)
My own debugger loaded with xc3sprog modified. I load the pic VIA jtag.
Works very well.
It would be MOST nice to be able to compile MMbasic with this totally
open source tool chain :).
I posted a question at to whether anyone else had done this yet and
I guess the answer is not yet!
May I suggest a few steps:
1. post symbol table / map file for each version of MMbasic along with
the hex file to make customization easier.
2. Consider adding to MMbasic source RAM modifiable patch points in the
idle loop and one of the constant rate ticks (timer 3?) so my seperately
compiled 'drivers' can keep time and get processor as needed.
3. Make a long term plan to allow loading of elf 'kernel' modules into
pic32 memory. i.e.- necessary flags and RAM boundary pointers.
I have noticed that with my home grown debugger/disassembler I can find
places in ROM that need to be patched without too much effort even without
a real symbol table/map file so that is very nice. Now to just make it easier.
warm regards,
Wiz
p.s.
A review of the 2.5.hex file will reveal that cfg3 1fc02ff0 is NOT
being set according to microchip docs!!
Also, there is a jump at 1d004380 or so to the middle of no where?
So unless Microchip tools are doing some editing, their tool chain
seems to have some problems?
Is there a 'regular' e-mail way to post to this list?
This on-line editor is NOT fun to use!
vasi
Posted: 01:13pm 31 Jul 2011
Thank you very much Jimbo!
Vasi
vasi
Posted: 04:38pm 31 Jul 2011
Hi WIzard,
[quote]It would be MOST nice to be able to compile MMbasic with this totally
open source tool chain :). [/quote]
What you mean? You didn't succeeded? If you did, why not helping in this area?
With your toolchain, you can get a smaller size of the compiled project? What are the benefits apart from having a non-restricted compiler?
Vasi
P.S. You are using Google Chrome or Chromium? The "bad" formatting of your post it may be from there....Edited by vasi 2011-08-02
wizard
Posted: 03:33pm 01 Aug 2011
Hi Vasi,
I haven't given compilation with openwrt tool chain a real try yet.
But previous attempts got stuck in the include mess :(.
And I have found that non-manufacturer support tools give MUCH
less hassle in the long run.
So I usually take the rugged road.
Any chance of getting a symbol table/ map file for 2.5 posted?
warm regards,
Wiz
vasi
Posted: 04:32pm 01 Aug 2011
Hi Wizard,
Here is another alternative to the Microchip C32 compiler. Is named Pinguino32X, it don't have restrictions (full optimization is available), is compiled from the free sources of C32 compiler and as library, the team ported newlib. They also are working to port Arduino library entirely (the team is years ahead of Mpide team which try to do the same and have Microchip technicians support). I think Pinguino32X is a great alternative. But of course, you can't just compile the Maximite sources, needs some configurations regarding to "include/lib" paths.
Vasi
P.S. they use a newer version of gcc than the one used by the Mpide team.
Here is the linux version and a Mac OS X one is planned.Edited by vasi 2011-08-03
wizard
Posted: 08:03pm 01 Aug 2011
Hi Vasi,
Interesting site. Thanks.
I just started to try to compile with my working tool chain.
Lots of headers missing or not in build chain.
I guess at this point a symbol table/map file would be of help, but so
far not in evidence?
I gather that compiling with Microchip's tools takes the right version, etc. Sounds
like could be quite an effort to get it working.
Maybe I can patch 2.5.hex to get it working here? Right now keyboard doesn't
work correctly. Seems to be a timing issue since a slower keyboard with the bits
coming out slower works a little better?
My chip is somewhat old, so this may also be an issue.
Wiz
