Local Time 23:00 25 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : sd card format through pc to maxi
sparkey
Posted: 07:21pm 21 Jun 2011
is it possable to format a sd card loaded in the maxi using some sort of terminal prog or other program via usb connection...thank you...
stuarts
Posted: 11:13pm 21 Jun 2011
Sparkey, not at this point. There has been a request to be able to format a card on the maximite, but not available yet. If you dont have a card reader for your PC, maybe you have a digital camera that you could format the card in if it needs it.
Stuart
Time is nature's way of keeping everything from happening all at once.
