Local Time 15:07 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : pinout questionre confused
sparkey
Posted: 10:06am 30 Jun 2011
the only true pinnout for the maxi is in the maxi manual ...i take it is this correct as i dont want to blow up the freq/period sections <pins 11 to 14 > ...looking straight at the maxi pins from top view if it had a vertical headder socket ...am i correct here ...thanks for any replies ....its nice to say thank you ...manners...
rhamer
Posted: 11:06am 30 Jun 2011
  sparkey said   the only true pinnout for the maxi is in the maxi manual ...i take it is this correct as i dont want to blow up the freq/period sections <pins 11 to 14 > ...looking straight at the maxi pins from top view if it had a vertical headder socket ...am i correct here ...thanks for any replies ....its nice to say thank you ...manners...
Be careful, the right angle connector is backwards.
I'm pretty sure pin 1 is marked on the board.
If you used a straight connector instead of the right angle one then the notch should point to the edge of the board.
Pin 1 is next to the keyboard connector and the edge of the board.
The ribbon cable counts in order from 1 to 26.
The IDC connector counts in a zig zag.
[code]
eg
2 4 6 8 10 12 14 16 18 20 22 24 26
1 3 5 7 9 11 13 15 17 19 21 23 25
[/code]
Rohan
Edited by rhamer 2011-07-01
Rohan Hamer
HAMFIELD Software & Hardware Solutions
Makers of the Maximite Expander.
http://www.hamfield.com.au
James_From_Canb
Posted: 11:09am 30 Jun 2011
When in doubt, measure it.
For example, run this:
' Change line 10 each time you run this
10 P = 11
' make each pin a digital output and set each pin low
20 for n = 1 to 20: setpin n,8: pin(n) = 0: next n
' set the selected pin High. It will be the only one (except the 3.3V and 5V lines) that is high.
30 Pin(P) = 1
Then get a multimeter and check the DC voltage between the pin you think is 11 and Ground
Change line 10 to P = 12, and repeat.
