Local Time 17:10 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : pin confusion
sparkey
Posted: 11:45am 30 Jun 2011
ijust got some pinnouts for the 26 pin headder which is pin 1 i/o pin
ok pin 21 on the headder is actully pin 1 i/O ami correct hereEdited by sparkey 2011-07-01
rhamer
Posted: 01:22pm 30 Jun 2011
  sparkey said   ijust got some pinnouts for the 26 pin headder which is pin 1 i/o pin
NO
Pin(1) is pin 6 on the IDC Connector
Or to say it in my preferred language
I/O Channel 1 is on IDC pin 6
Remember to ignore the pin numbering on the right angle IDC connector, it is wrong.
go from the circuit diagram.
The picture in the user manual is of the backwards right angle connector.
RohanEdited by rhamer 2011-07-01
Rohan Hamer
HAMFIELD Software & Hardware Solutions
Makers of the Maximite Expander.
http://www.hamfield.com.au
James_From_Canb
Posted: 09:11pm 30 Jun 2011
Alternately, look at the pin-holes in the cable connector [ie cable pointing away from you, connector facing you].
Then the diagram is correct.
James
Keith @
Posted: 03:04am 04 Jul 2011
If the Silicon Chip schematic (fig.1) on page 33 of the March 2011 edition is correct then I would would go so far as to say PIC32 pin 12 is I/O 1 connected to IDC 6 and which is labeled as pin 1 on the IDC drawing when looking at the back of the Maximite
Has anyone found any problems with this drawing (unlike the discussion elsewhere on the forum which is a tad confusing) on the IDC pinout drawing which is supposed to have errors.
I can't see any problems except that it doesn't conform to a standard.
regards
Keith
The more we know, the more we know we don't know !
sparkey
Posted: 06:06am 04 Jul 2011
thank you
rhamer
Posted: 12:38pm 04 Jul 2011
  Keith @ said   If the Silicon Chip schematic (fig.1) on page 33 of the March 2011 edition is correct then I would would go so far as to say PIC32 pin 12 is I/O 1 connected to IDC 6 and which is labeled as pin 1 on the IDC drawing when looking at the back of the Maximite
regards
Keith
Yeah, the 3.3 & 5 v pins are reversed on that diagram.
Rohan
Rohan Hamer
aargee
Posted: 10:22pm 04 Jul 2011
Don't use the Silicon Chip diagram, go to Geoff's Maximite page and use that one. The SC diagram has quite a few errors...
- Rob.
