Local Time 15:05 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Autorun.bas
Talbit
Posted: 06:53am 02 Jul 2011
I cant' get autorun.bas to work. I have myprog.bas and autorun.bas in the SD root and in autorun.bas I have run "myprog.bas"
All I get is the Maximite red LED stays on hard.
run "myprog.bas" works if I don't have autorun.bas in the SD root.
Talbit
Talbit
James_From_Canb
Posted: 07:10am 02 Jul 2011
Try a line number first.
10 run "myprog.bas"
Talbit
Posted: 07:15am 02 Jul 2011
You're a genius!
Perfect.
Talbit
Talbit
stuarts
Posted: 11:58am 02 Jul 2011
Talbit, or just load myprog.bas and then save it as autorun.bas.
Stuart
Time is nature's way of keeping everything from happening all at once.
Talbit
Posted: 12:32pm 02 Jul 2011
That makes even more sense!
It works.
Thanks.
Talbit
Talbit
