Local Time 17:10 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ok i`m a newbie here but what is 12c
sparkey
Posted: 05:06pm 07 Jul 2011
ok fine i guess its a way of connectting a printer to certain pins on the maxi but softwhare wont do it alone u need to be able to con figure the hard whare to match this with ...look ..i can connect just about any thing i want to the maxi but to get it to communicate is a whole bottle of fish in a fish bowel ..regards spoarkey
Ray B
Posted: 12:28am 08 Jul 2011
12C is a type of serial communications format similar to "1-Wire" which allows you to interface with a whole lot of addressable devices like very accurate (0.25C) digital temperature sensors, EEPROM, RTC etc all over the same pair of wires.
If you don't know the terms I'm using then GOOGLE them starting with Interfacing 12C
RayB from Perth WA
