Local Time 16:05 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SD Card Reset.
aargee
Posted: 11:17am 13 Jul 2011
Odd question, when the SD Card is inserted live, should the Maximite reset?
stuarts
Posted: 11:39am 13 Jul 2011
I understand that its not supported to swap it live, but it works on mine
Stuart
Time is nature's way of keeping everything from happening all at once.
seco61
Posted: 11:48am 13 Jul 2011
My understanding is this should work OK (and does on my PCBs - but I have added extra decoupling...).
However, depending on your decoupling caps, the "power spike" that occurs when the card is inserted and initially powers up could reset the PIC.
Add some extra decoupling around the SD card socket to smooth the power rail and see if that helps (again, LOW ESR caps are the way to go!).
Gerard
Gerard (vk3cg/vk3grs)
VK6MRG
Posted: 12:12pm 13 Jul 2011
I used to swap my SD card from the Maximite to the PC all the time with it running programs to edit the Basic software I was writing with no problems!
Now I just use HyperTerminal and cut and paste with note pad.
