Local Time 17:11 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SD Card Socket
jman
Posted: 07:52am 23 Jul 2011
Does anybody have a source for the SD socket (other than Altronics)
VK6MRG
Posted: 09:43am 23 Jul 2011
TRY RS part numbers 502-5004 about $3 or 455-9102 about $15
http://australia.rs-online.com/web/search/searchBrowseAction .html?method=searchProducts&lastSearch=&autoc=false&storedtf gList=&searchTerm=502-5004&x=0&y=0
http://australia.rs-online.com/web/search/searchBrowseAction .html?method=searchProducts&lastSearch=&autoc=false&storedtf gList=&searchTerm=455-9102&x=0&y=0
Hope this helps.
PS, current RS catalouge is over 2500 pages!
Posted: 01:10am 24 Jul 2011
neither of those look right to me. Unless I mis-read them, Data sheets show the conencions at the rear not internally.
glenn
VK3PE
jman
Posted: 01:44am 24 Jul 2011
I thought the same.
Maybe we can find a cheap Ebay one that fits but so far all the one's I have looked
at dont look like it
VK6MRG
Posted: 02:01am 24 Jul 2011
ELEMENT 14
part number 1318471
MOLEX-5009980900
http://au.element14.com/molex/5009980900/card-sdcc-standard- mount/dp/1318471
Posted: 02:03am 24 Jul 2011
Yes, big problem.
I have looked through Farnell and RS data sheets and can't find that part or similar. Jaycar don't have it. Altronics don't have them either. Saving them for kits i guess.
VK3PE
donmck
Posted: 02:08am 24 Jul 2011
  VK6MRG said   ELEMENT 14
part number 1318471
MOLEX-5009980900
I have been looking myself, they look correct, but they ain't cheap.
$10.09 each and no qty discounts.
Cheers Don...
https://www.dontronics.com
Posted: 02:33am 24 Jul 2011
They look similar but are not the same footprint.....
glenn
VK3PE
jman
Posted: 02:43am 24 Jul 2011
I think we have a winner
Site does not mention that there is no stock
http://www.voltelectronics.co.nz/new-sd-secure-digital-conne ctor-surface-mount.html
seco61
Posted: 04:14am 24 Jul 2011
  jman said   I think we have a winner
Hi John.
Whilst I hope that they will have stock, I notice that the part number is the same as the Altronics part number. And the store web site seems to imply that they request the parts from their wholesalers and then send them on.
I am guessing that the Altronics wholesale arm would be the supplier in this case and therefore we may suffer the same delays.....
I also noticed that the store is located in Croydon Nth Victoria, so I may give them a call tomorrow to find out the stock status.
I have previously tried to get this particular SD card direct from the manufacturers distributor, and also tried the free sample path, but have had no luck.
Gerard (vk3cg/vk3grs)
Gadget
Posted: 04:54am 24 Jul 2011
part number 1318471
MOLEX-5009980900
I have a element 14 account and a contact who i get to quote on pricing, and more often tnah not he comes back with a price half of what is on the web, tomorrow I'll find out how much I can get them from. what quantities are people wanting?
Terry
VK6MRG
Posted: 05:00am 24 Jul 2011
If these are the correct type required for the Maximite V2 design from Geoff Graham, I'll take 2.
But looking at the specs it may not be!Edited by VK6MRG 2011-07-25
Posted: 05:47am 24 Jul 2011
  VK6MRG said   If these are the correct type required for the Maximite V2 design from Geoff Graham, I'll take 2.
There is an alternative Maximite planned but it is very early days and the type of socket is not fixed. Also this design will not replace the original Maximite - it will supplement it.
This illustrates the problem with CD sockets... there seems to be a lot of variants. When I designed the Maximite I went for the Oupiin socket (from Altronics) as they were the only ones easily available from a retail outlet. Now that Altronics cannot supply I am not sure what to do in any future designs...
VK6MRG
Posted: 06:23am 24 Jul 2011
How about micro SD or a CF card?
Posted: 07:12am 24 Jul 2011
Hi Geoff,
Parts are a big problem. I would tend to at least dual footprint the Altronics and Jaycar ones. Maybe even a Farnell type also
The power switch and DE15 fall into same category too. The one specified is a wide spaced type. The narrow ones seem to be easier to get.
glenn
VK3PE
aargee
Posted: 07:30am 24 Jul 2011
Just build the UBW one - and fudge all the hardware :-).
I must admit, the PCB built Maximite does look a tad better!
seco61
Posted: 10:11am 25 Jul 2011
Hi All.
My backorder with Altronics (dated 28/6) for some SD card sockets was filled today and should arrive tomorrow. So hopefully their warehouse now has a large stock and supply the stores, internet orders etc.
Gerard (vl3cg/vk3grs)
aargee
Posted: 11:17am 25 Jul 2011
How do you check backordered items at Altronics?
Their website doesn't seem to show backorders only what was originally ordered.
- Rob.
(probably have to use the telling bone).
