Local Time 10:35 08 Aug 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : at this moment
sparkey
Posted: 01:25am 18 Aug 2011
right at this moment i am running my inverter running my computer with a current draw of 2 amps from the batterys its clody out side and i`m only getting 2 amps from the panels so the maxi inverter is on the road ,,well all boxed up and firing on both cylinders thanks to all who played a part on helping me achive this oh
:m/s/ratio is at 50 percent and the freqency is at 200 Hz..."houston we have lift off"....
would also like to add im running a kvm switch so i am only running one lcd screen 19 inch and the mouse plus directly into the computer dont use the mouse plug on the maxi si its just dagging around till we get a mouse function...you carnt stop progress!!!!!...
:well its time to fire up the stereo and see how she performs with drawing 5 or 6 amps through this thing ...Edited by sparkey 2011-08-19
