Local Time 10:34 08 Aug 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : hamfield board pwr supply
sparkey
Posted: 05:38am 20 Aug 2011
short note if you r using one of the add on boards from hamfield that has three regs on it and are using the regs to their potential you will require a suppy of three amps
: :typically i recomend a two amp 14 volt generally the twelve volt reg should have three volts higher than its out put the 5volt and 3,3 volt should not be a problem as these regulators r capeable of a much higher input voltage but just rember ::its all about current::
:regards sparkey :: Edited by sparkey 2011-08-21
